EGR/AIR Block Off plates, what do they do?
I am getting a p1404 code which I am told is the egr. Will my car pass a New York state inspection (has cats) w/o the egr. If so, is there a diagram for dummies so I can block it off or remove it? Thanks.
Im not schocked, NY sucks w/ emmitions. I have heard about people cleaning it &lor the pinicle but im not sure how to do it or if it is worth a try. Thabks for the reply.
It does have the 1404 s*&^. Where is it located please? Stupid question, I also got a p0343 cam position sensor they are two totally seperate systems I thought. Wierd that they both went off right after a tune. Except for a lil rough idle the car runs great to me.
ok i know this is a few weeks old but im in the process of getting headers and wanted to go with tsp headers on my 99 z28. but ill have to remove the egr. now there is a hose that goes from manafold to manafold around the back of the motor and i believe it actually has a T in the hose back to the back of the intake is this correct? and if it is do i just block it? do they sell something that blocks it? any help would be great
If you're getting headers without emissions junk, there's nothing to block off - you can just pull the air plumbing out and toss it in the trash. Pull the relay for the air pump, and you can yank the pump out if you want - should be behind the turn signal lamps on the driver's side. For the EGR system, you will need one of the expanding rubber plugs to seal the hole in the top of the intake behind the throttle body, unless you already have an LS6 intake.
well looked at it better yesterday, dont know what i was thinking about going to the back of the intake. looks easy to removal all though should clean up nice. thanks for all the help also.
