Newb Head questions
Newb Head questions
Hi guys, I have a question regarding heads on the LQ4/6. Being in the uk I am planning on buying my engine from an importer who specialises in LS engines. Did the LQ4/6 ever come with rectangle port heads? Which are the best heads to look out for on the truck engines?
The LQ4 or the LQ9 will have cathedral port's. They also got the #317 casting heads. The difference between the 2 engines is the pistons, LQ4 has a dish piston and 317's for 9.5:1 compression. The LQ9 has a flat top piston with 317's for 10:1 compression.
What engine are you getting LQ4 or LQ9 ?
LS1Tech Premium Sponsor
No matter what cylinder head you decide to use, I would make sure you know what camshaft you are going to go with first, so you can determine how much you will be mill without having to flycutt the pistons (if that is even a big deal to you).
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
garygnu - I can get 93 or 97 at nearly every petrol station over here, I'm planning on getting the engine in and running in standard trim then fitting some rectangle heads with a carb style manifold cam etc. this is a pic hopefully of the car it's going in
