new guy from the pacific northwest thinking of building a 312cid ls
the reason is that i have a very light car and a trans axle that is limited in torque capacity.
why 312? well i have a line on a ls1 5.7 and a 4.8 short block. the 5.7 has a questionable lower end. so for cheap i think i could put together a rev happy 312 ci that will put out really good power.
so has any one done this yet?
i think your getting bad info on lsx motors from someone lol
again thats not that common. yea it happens but no more so than any other motor. all my time with ls1's and friends with ls'1s ive seen it once. the stock crank in the ls1 is plenty fine most of us here keep it even past 700hp.
i will be building a 312 ci motor from a 4.8 crank and rod set using a ls1 block and pistons to get a engine with the characteristics of power higher in the rev range and lower torque than a ls1 configuration.
i am NOT questioning the soundness of the ls1 lower end but stating that in this ls1 that i have an option to pick up, it has a known fault as in a spun rod bearing and the mains show undesirable wear and will need machining of the crank and rods to make servicable again.
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I think I'd be pulling the crank before believing the
spun bearings story. Rods don't care about bearings,
the wear face is at the crank. And I'd be surprised if
more than one "spun", unless the thing ran completely
dry.
I've never had a spun bearing in any of my 20+ cars
including the 4 or so motors I have personally rebuilt.
I don't know how people manage it.
The 5.7 will be plenty rev-happy with a cam swap,
and ought to be marginally lighter than the 4.8 iron
block I expect.
dry.
block I expect.
dry.
block I expect.
dry.
block I expect.
again i would only be using the "crank and rods" from the 4.8!
i know i'm new here but i'm kinda dismayed here with the lack of responses from knowledgeable people.
granted most of you guys are pushing around 3,300 - 4,000 pound boats and need all the torque you can get...... but i'm dropping this in to just 2,200 car with the engine in it. monster torque is not what i need!
That combo isn't a popular choice. Some older members have posted, sorry that nobody has the plethora of knowledge you demand.You were VERY vague on what kind of vehicle the motor was going in. G/L NOOB
