98 T/A cheap mods
98 T/A cheap mods
I have a 98trans am and have a great opportunity at some cheap small block parts, I have the availability of a set of lq4 heads out of a express van, and a brand new 6.2 cam, is it worth putting these parts on my ls1? If so which ones, and if the heads is it worth getting those heads machined or what else, the car is factory except I think a higher performance clutch and a slp performance loudmouth exhaust, my quickest time at the midnight drags here in Salt Lake is a 14.20, any input is greatly appreciated
I wouldn't use any parts. If you haven't already I would shop around for a set of longtubes and a good y pipe. I would also get a ls6 intake to complement the exhaust. As for cam and head packages I would give Texas Speed or Martin at Tick Performance a call. Both are very helpful and can set you up with everything you need and find a setup that matches your budget and goals.
ok cool cool, or is it worth refreshing this lq4 block and running it in the t/a? is it too heavy? would I use the lq4 heads with it? or my ls1 heads? what else different would I need if I went the lq4 6.0 route, would it be worth boring it also? I know you can't bore the ls1, I guess what I'm getting at is the extra weight worth the potential power gains
Thank you 2000 pewterta good insight, my ls1 is ay 165000 miles and as far as I know never been overhauled it does still run really good however so I'm not sure what to do, now here's more questions, if I do decide to overhaul the lq4 engine is it better to use those heads or should I use the ls1 heads? I/m assuming everything will bolt up terrific, should I get different injectors for the 6.0 or stick with stock ls1? So many queations
