Most HP you can recover from dirty fuel filter?
Will be replacing the fuel filter on my Ls1 Camaro soon. The car has almost 100,000 miles on it and it has never been changed. Any chance of picking up maybe 5HP on a new filter or maybe increased fuel economy?
You may pick up 5hp that was lost from it, sure, and possibly see fuel economy come back. Probably a very small gain but every bit helps. It is definitely satisfying enough to know that you're getting nice clean fuel in the engine for the first time in 100,000 miles! It's an easy replacement and you'll probably find yourself doing it a little more often after seeing how easy and cheap it is!
Noticed you have a ported TB, how much did that help your car out? Could you feel the difference at all?
I just ordered one, started a thread on it here asking some questions:
https://ls1tech.com/forums/new-ls1-o...ower-part.html
Nice, I'm interested to look at my fuel filter once I pull it off and see how dirty it is. Since I'm racing the car again every little bit helps.
As far as the ported TB, to be completely honest, it was on the car when I bought it. But I saw that you have a lid. The lid plus the TB should help quite a bit, at least enough to feel the throttle response. Once you tune it up real good and put the ported TB along with the exhaust you have and all, it might not be a bad idea to start thinking of doing a tune on it if you haven't already.
You will see a lot of very dirty fuel come out of that filter. I changed mine this winter and it hadn't been changed in about 5 years. I feel that it helped make a difference however I did a lot of tuneup stuff at once so I can't tell what it alone did.
Yeah, just ordered the ported & polished TB with coolant bypass lines, guess those lines help in some small way. Will make 3 minor mods:
-P&P TB
-Lid
-Catback exhaust
By leaving it untuned am I going to hurt anything or make it run lean? Or would getting a tune just maximize the horsepower from the mods?
Yeah, speaking of tune ups, I need to change my plugs and wires too, will probably do those soon as well.
-P&P TB
-Lid
-Catback exhaust
-P&P TB
-Lid
-Catback exhaust
It won't hurt the car if you leave it untuned, but yes it would definitely maximize gains and improve gas mileage as well as overall driveability. It would be more dire if you were getting longtubes on along with the rest of the exhaust and the above mentioned mods. But a mail order tune is right about $150.00 and if you don't plan on doing an extreme amount more for the time being after you do those mods, it would definitely be in your best interest to get it done! You will be glad you did!
Also when you do the fuel filter it may also be a good idea to do use some seafoam as well just to clean out the engine. If you haven't used it before, there are plenty of videos/how-tos on here or youtube.
Let me know what all you end up doing and how much these mods wake up your LS1!
