What cam???
I'm about to purchased a cam but I have no idea on what to go with. My car is not a daily driver but I do enjoy driving it to work from time to time. I have an 01 ss with 50k on the engine. Mods I have are k&n intake fast 92/92 with long tube headers and a 3 inch Y pipe with slp loud mouth. I'm leaning toward maybe ms3 or ms4 but I have no idea if I should look in to something else.
Its more of a street/weekend warrior car I never took it to the track or really care about going. Also don't plan on doing any major work besides a cam to the car unless I blow it up. But you never know once I have the cam I might want more but as of now I only want a cam. Oh yea also its a 6 speed with 4.10 gears.
if you want a radical that needs a 4000+rpm stall ,look at a T-rek or a big EPS cam.depending on your gears and tranny set up a torquer v3 makes good power.the more radical cams need the springs tested or replaced every 20k.a torquer v2 is easier on springs.
This one here seems to make great power and would work for your set-up...
Or at least drop Martin a PM to get his suggestion for ya
http://www.tickperformance.com/tick-...1-ls6-engines/
Geez Martin an hour for lunch!! You must be a slow eater or go out for lunch!! See OP just ask and your wishes will be granted!! Good Luck with the mods!! Larry
