What air filter do you use?
Old 04-23-2004 | 01:52 PM
FAST99Z's Avatar
Default What air filter do you use?
Have a K&N with the airbox mod and ram air on my 99 camaro. I have recharged the K&N twice and each time I find some dirt and grit particles in the airbox. They look small enough to be able to pass through the mesh in the filter and I bet some have.
Anyone using a high performance paper filter or does a stock paper filter work? Let me know what you are using.
Thanks
Old 04-23-2004 | 02:13 PM
Zo6Killer's Avatar
I use an ACCEL Kool Blue. I shake it out every couple of thousand miles. If anything has gotten through it, it hasn't hurt anything yet! I was going to go with a clear lid (and may still) and thought the blue filter would look cool.
Patman's Avatar
I use the stock AC Delco filter in my car, and a Fram air filter in my wife's car, and in my oil analysis results both of these filters have proven to trap dirt very well. K&N air filters are terrible at stopping dirt from entering the engine.
Old 04-23-2004 | 02:17 PM
PSU_Engineer's Avatar
Hey Patman,
Thanks to your recommendations I just started using only Baldwin filters in the Camaro. I decided to burn the K&N in my driveway after completing Baldwin filter change. It burns quite nicely
Thank You for setting me straight,
Tony
Old 04-23-2004 | 03:22 PM
ZR2877's Avatar
I ditched the K&N and now use a FRAM air filter.
Old 04-23-2004 | 03:31 PM
jimmyblue's Avatar
Moderator
I use Purolator because I flow tested 4 paper types
and it came in 2nd (behind the SLP Blackwing filter)
for best pressure drop. Slightly better than Fram,
both better than GM OE paper filter. I didn't test
any foam filters but won't be using them, either.
Old 04-23-2004 | 04:39 PM
gymratt's Avatar
7 dollar Fram here!
Fred99LS1's Avatar
I use a K&N filter, free mods on the air box and a SSRA to feed it. If you keep the K&N filter charged(Red), doesn't it adequately stop dirt & allow much more CFM to pass???
I atleast think that may be true & I'm more about making power. Maybe a paper filter is just as good, please advise, Fred
Old 04-23-2004 | 04:52 PM
Silverbird01's Avatar
Same here. I haven't noticed any difference or loss of performance at all.
Old 04-23-2004 | 07:30 PM
FAST99Z's Avatar
I don't think the K&N can stop small grit like sand or dirt, so I am going to change to the FRAM. Sand in the crankcase could be a BAD thing.
Old 04-23-2004 | 07:32 PM
TX_SS's Avatar
Holley filter here..it works ...very nice...and fits...tight..
Old 04-23-2004 | 07:36 PM
Danny2tek's Avatar
I'm about to ditch my K&N
Old 04-23-2004 | 08:36 PM
bigdsz's Avatar
Wix has a filter with very deep pleats, in fact they're so deep some of them get slightly smashed on installation. Lots of surface area. I don't know the part number off hand.
Old 04-23-2004 | 08:45 PM
f-bodman's Avatar
Don't know if this is true or not, but when I did a search on here when I was trying to decide what filter to get a lot of guys said that the K&N is not made specifically for our cars. They said that's why it came with a foam strip, to make it fit tight.
Old 04-23-2004 | 10:24 PM
XtinctHawk02's Avatar
Holley Powershot.
Old 04-24-2004 | 01:03 AM
T/Ajammer's Avatar
I just pulled my K&N and put in a Fram. Don't know for sure, but suspect the K&N was the reason for my mass sensor getting dirty although I didn't find anything on the inside of the SLP high flow lid. Can't tell much difference in power between the two filters anyway.
Old 04-24-2004 | 01:21 AM
Cheatin' Chad's Avatar
Holley Powershot
blue filter looks cool under my clear lid,good fitment,no gasket required.
Old 04-24-2004 | 01:32 AM
tuffluck's Avatar
no. it does not.
Old 04-24-2004 | 08:55 AM
davered00ss's Avatar
Moderator
I got rid of the K&N for a Fram.
Old 04-24-2004 | 10:58 AM
jpz28's Avatar
I use the Holley Powershot filter ....looks cool with the clear lid...I also have the K&N but won't use it....Does The Holley worlk better than the K&N??..how bout for people with the FTRA application??..........
