160* stat problems????
183 on
176 off
196 on
186 off
Normally i see ECT cruising speeds (45+) of 183, in traffic it goes up. At the strip it was 225F. The poor automatic i think was moving alot of heat through the rad.
so the guage is not accurate in terms of 210 = 210 ....but it should fluctuate to show that the car is running cooler...since during morning startup it does stay low and then work its way up to the middle...at least mine is.
if your fan is on more often (i noticed that too), then maybe your guage is really that bad.
always be above 170 once warmed up, that's
just how they (mis)rate the thing. I see a low
end of 175F. I set my fans aggressively low to
get the thermostat to be in charge, FAN1 at
ON=177, OFF=176 and FAN2 ON=179, OFF=178.
So after hard running I get FAN2 for a little bit
but FAN1 only in moderate driving and no fan
if I'm rolling and get the airflow that way. Keeps
my temp range pretty tight (175 - 179F).
'99 - '02 model temp guages are a joke, nothing really more than an idiot light, the temp on them generally indicates "in the middle" of the range once engine is warmed up.
So, it's probably just that you guage is wrong.
If you can find someone with Autotap or other scanning equipment and have them read your PCM while the car is running. Chances are, you are really around the 180 deg. range.
