I need some heads
I have a stock LS1/T56 combo that I'm swapping into a 66 nova with a ford 8.8 rear end and 3:73 gears
The combo came out of a 02 Camaro ss so it currently has the 241 heads and ls6 intake.
I want to use the Tick performance stage 2 torquemax cam but I need some help picking out a set of heads for my budget. I was looking at the TSP 5.3 stage 2.5 heads as they seem rather popular but like most everyone else I want more power. I have a budget of $2000 set aside for heads so I would like to know if anyone knows of something in my higher budget bracket and if the power difference is worth it vs using the TSP 5.3 heads. I plan on running all the regular stuff along with the set up headers, ud pully, tune but would like to keep the ls6 intake.
I too am in the market for a budget head. I was looking at the PRC Stage 1.0 LS6 @ $1200 or PRC Stage 2.5 5.3L @ $1310 to complement my current cam/bolt-on/4000 stall set up. After a long talk with TS for only $300 more (base price) the PRC as-cast 225 would give more room to grow in the furture. Still works good with LS6 intake with plenty of P/V clearance for cam upgrade.
My question is how well will a set of ported AI ported 243 stack up against say some trickflow genx 220 cast or a set of prc 225 as cast? They all run around the in terms of cost but do any of them have a distinct performance advantage over the other etc
A used set of 317 heads is about 200 dollars and most machine shops can do a valve job, pocket port and mill to 65cc for around 400 dollars. With spring kit you should be able to have a good performance head for under a 1000 bucks. Buy some used 799 castings for around 450 - 500 dollars and they wont need to be milled or you can mill them for increased compression. The 317 head though flows pretty much the same as a 243 or 799 casting the only major difference is the larger chambers.
LS1Tech Premium Sponsor
PRC As cast all the way! I picked up right at 30rwhp over my stock 243s with them. Can't beat that for the money if you ask me.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
