Heads to Intake Manifold scratch/engraves
The o-ring on the gasket is thicker than those scratches so you are probably fine. If you are super worried about it, you could apply a very thin film of RTV to the area surrounding the port then carefully wipe off whatever doesn't fill in the grooves you created. Let it dry for a little bit before you put the I take on and you shouldn't loose sleep over it.
Don't beat yourself up about it. That wouldn't even make my top 100 stupid things I've done to a motor list.
It's not mine! woo hoo!
You did not ask a question; you just posted that you did something.
But, since I'm inferring you need advice, Mercier is right -- you're likely OK with new gaskets. I also like his idea with the RTV. I'd just apply it, fill, wipe like one would be doing drywall patching or the like. Everything should be perfectly fine from there.
I got new gaskets but still don't have my old motor even out of my truck because its winter time and I have non-heated garage. Should be camming my LS soon and then bringing my truck home and starting work ha.
Understood. I had the Jeep ready to go to the exhaust shop for a week now and we had a fricken monsoon come through. But that's Louisiana weather. I'll get it back Friday and it'll be 20 degrees then as soon as I get a tune done for it it'll be 95 degrees again and I'll be back in there installing the A/C kit.
