2000 Trans Am Wont Start
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
i recently bought a wrecked trans am with ls1 in it. It was rolled on its top neither one of the air bags deployed but the car turns over but wont start what should i do to fix the problem is the a fuel safety switch that needs to be reset or some other safety keeping it from starting thanks need to make sure engine runs before i pull it out to put it in another car
If you subscribe to the thread, you can be emailed when replies are posted. We don't get paid so it's definitely not worth the time to separately email you to address your problem.
I'd get a $20 fuel pressure test kit from Harbor Freight and check for proper pressure(40-60PSI). Then pull a plug(leave on the wire) and ground it to the head and turn over and see if you get spark. Spark + fuel = bang so always good to check those basic elements.
Good luck.
Good luck.
