codes galore ls1
codes galore ls1
I have a 98 z28a4 with 67,xxx original miles bone stock. when I got the car about 5 months ago the ses came on with code p0442. replaced gas cap and purge solenoid. ses came back on so I was like **** on this its a small evap leak, wont hurt anything. so I just drove it. then about a month ago my ac comp. stopped after blowing ice cold. now I hooked up a scanner AND have all these codes. p0107 p0405 p0442 p0530 p1404 p1635 somebody please help me out here what the heck??
P0107 is a MAP sensor low voltage code
P0405 is a EGR sensor A low circuit code
P1404 is a EGR stuck open code
P0442 is a EVAP small leak code
P1635 is a A/C, MAP, EGR voltage out of range code
If the car is bone stock I would start going over all the wiring harness and make sure it's all in tacked. Also check for vacuum leaks. Then start to bench test the MAP and EGR sensors.
