6.0 Spark plugs
6.0 Spark plugs
Hey guys, I'm new here. Just got a 2000 z28 with a 6.0/Lq9 in it.
Motor wise, its PRC heads, bullet cam, Texas speed forged bottom end.
It runs really well, the guy I got it off of said it could use plugs soon. He said he had been using NGK 56. I can't seem to find that plug, maybe there discontinued? Looking for some other ideas on what plugs to run, if those aren't available?
Thanks.
Thanks.
LS Engine Spark Plug Tech
Hi Dogz, I would use a greater SPG (.050"+) if possible.
My L92 came with a .060" SPG and ran fine.
GM LS started with a .065" SPG but changed to a lower "tech" gap of .045" because of a rough Idle.
The Spark Plug Gap can effect fuel consumption, too small = more fuel used.
A larger SPG will make more HP when the Coil Dwell settings are correct AND when the fitted coil has the ability to fire.
Lance
Lance
