New ls1 question
New ls1 question
So new to the forum and got a few questions hopn you guys might be able to help out.
I picked up a 01 formula with 113k on it. The guy I bought it from said he upgraded a few things.
779 heads supposedly he portmatched and ported them, 220/560 cam, ls6 intake, melling high pressure pump, 3.42 auburn rear. , roller chain and 3point gear
im curious what kind of hp/tq i might be looking at and also ive got a odd issue. When i start the car it struggles form a second the starts kind of shitty then smooths right out. The idle hunts for a minute just a bit and will surge in gear a bit but then smooths out. Any ideas on a cause? I've checked for vac leaks and found none.
he said it hadnt been tuned. Any input would be appreciated.
I didn't think just the heads, cam and intake were very big changes to the point a tune would be crucial. It's not a radical cam by Any means i thought. Do i need to go get a dyno tune or do you think a handheld would be ok
A handheld tune might get you by for a bit, but i wouldn't even consider that for a permanent thing. Yes adding a HCI is a huge change and running it permanently untuned like that is insane
