Need help check engine light on
Old Apr 22, 2018 | 02:06 AM
Goobermix's Avatar
Default Need help check engine light on
just bought a 98 ws6. And the check engine light is on I thought it might have been the spark plugs but i changed them and that wasn’t the problem
p0131 bank 1 sensor 1
po151 bank 2 sensor 1
It seems to idle fine and cruising on highway is fine but when I give gas it fills like it pudders or not getting enough gas.
Old Apr 22, 2018 | 07:58 AM
B52bombardier1's Avatar
Those are both related to your oxygen sensors. Check the wiring at each sensor. You might need to replace them though let's see what others here say first. My wife used to buy cheap gas at Valero and Citgo and had trouble with O2 sensors but not any more once I convinced her to buy a Top Tier fuel. Yes, the better dead dinosaur fuel juice costs more but its better for the vehicle. Pay now or pay later and go through some hassle.
Rick
Old Apr 22, 2018 | 12:56 PM
Goobermix's Avatar
Rick
thanks for the info.
Old Apr 22, 2018 | 01:26 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
These are low voltage codes for both front O2s. You probably need to replace both forward (pre-cat) O2 sensors. Either that or, as mentioned above, there could be a wiring issue somewhere in the harness for the front O2s.
Spark plugs aren't going to be the issue here.
Old Apr 22, 2018 | 05:27 PM
Goobermix's Avatar
thay are low voltage. Besides wiring issues and bad o2 sensors is there Anything else that would cause these codes to come on
Old Apr 22, 2018 | 05:45 PM
Goobermix's Avatar
Also just a update. The car start idling @ 1050RPM’s this started after adding the spark plugs.
Old Apr 22, 2018 | 06:01 PM
RPM WS6's Avatar
Not that I can think of, other than perhaps some sort of PCM failure - but then I suspect you'd have some other codes and/or major operational issues as well.
Old Apr 28, 2018 | 11:53 PM
Goobermix's Avatar
[QUOTE=Goobermix;19882028]
MASs air flow sensor was the problem
