Transmission Fluid
If this is in the wrong section please let me know ill remove it.
Simple (Probably stupid) question. What transmission fluid are you guys running in your t56 and how much fluid do you put in if the transmission is empty?
Thank you!
Thank you!
4 qts. Dexron III
I did some research and I heard this is what people have been using in there transmissions Would you recommend this?
I run the Mobil1 synthetic in my t56. They hold a gallon (4 qts) when empty.
