Here's the deal, trims account for weather or altitude changes from your base fuel map. If i tune today, then run the tune, its still perfect. It will hit target with little to no trims. Any variances you add like weather or parts changes will make it slightly incorrect. If you limit those (from your original base tune) limited trims are needed. In simple terms (and your own experience), if you tune in the summer, go to the track in the fall where the air is better, you'll see the car running slightly lean. You could most likely add a simple sweeping correction to your entire fuel map and get very close, say 5-8% add. If you ran in the late fall it may be more. Next year back to summer you would slowly undo those changes as air got less dense. 02s and MAF simply do this for you, without them, you'll need to do it yourself. So it's just a matter of how much you want to stay on top of it.
Speed density is no MAF. Closed loop is 02s, open loop is no 02s. I run speed density closed loop, and so far the car has driven great, it trims with weather changes and hits target AFR (or pretty dang close) even on race fuel. The only reason I could see going open loop is if the 02s wont work with a leaded race fuel you are running or are causing incorrect trims leading to bad AFRs that you can't seem to fix. But, if they work or will work, I recommend keeping them.
