02 Ws6 m6
Old Aug 19, 2018 | 08:55 AM
BitPilot77's Avatar
Default 02 Ws6 m6
Good day
I'm looking for recipes for 450whp and would like to have great driveability on street , no track or road race events just a fairweather driver . stock car so far , I have a kooks y coming and magnaflo cat back . Will speed engineering headers work with looks y?
my budget will be 10000 CAD . Also any reputable shops in Edmonton area , I built an 88 and came to conclusion that shops locally are very weak , gore you and cant follow through.
Old Aug 19, 2018 | 09:39 PM
jaxcam02's Avatar
My set up is in your range.
SSRA scoop
FTP 98mm lid
85 mm Delphi MAF
92mm Holley throttle body
90mm Dorman LS2 intake
42 lb injectors
25% underdrive pulley
Texas speed PRC stage 1.0 heads
11/32 pushrods
Texas speed Torquer v2 cam
Speed engineering headers and true dual exhaust.
If you find parts similar to these you should be close to what you want
Old Aug 19, 2018 | 09:58 PM
BitPilot77's Avatar
SSRA scoop
FTP 98mm lid
85 mm Delphi MAF
42 lb injectors
11/32 pushrods
ok I was looking at hawks 450 rwhp kit but I'm reading the lsx 102 there is lots of bucking or surging on street ?
Old Aug 20, 2018 | 03:50 AM
HCI2000SS's Avatar
Are you looking to build an LS1 here?
Old Aug 20, 2018 | 08:33 AM
BitPilot77's Avatar
correct .... possibly ls6
Old Aug 20, 2018 | 10:19 PM
jaxcam02's Avatar
I feel like that bucking is all in the cam and the tune. I was looking at the 102 as well but I wasn't doing anything crazy with my heads to merit going with that big of an intake
Old Aug 20, 2018 | 10:28 PM
BitPilot77's Avatar
ok , sounds good I just want to be able to hang with newer dodge ford GM cars without a huge cam with issues I've heard about the v2 cam hood things
Old Aug 21, 2018 | 02:08 PM
jaxcam02's Avatar
I do get bucking with my v2 in parking lot and you notice it a little bit at constant speed on the hwy occasionally.
Old Aug 21, 2018 | 03:27 PM
BitPilot77's Avatar
hmmm yeah I deff dont want that .....I'll ask around
Old Aug 21, 2018 | 03:44 PM
98CayenneT/A's Avatar
With a good tuner you should not have any bucking or surging. My buddy ran the v2 with zero issues. I have no bucking or surging with the setup in my sig. My buddy runs the Tick sns sg3 with no issues
Old Aug 21, 2018 | 04:46 PM
HCI2000SS's Avatar
Perception and matter of opinion come into play as well. No way will any moderate sized cam drive like stock, but a great tune can greatly minimize drivability issues. There's always going to be a trade off when making more power. Sometimes the bucking or surging is largely coming from other things such as the clutch, drivetrain, etc... It's all a matter of what you are willing to give up in order to make more power
Old Aug 21, 2018 | 05:19 PM
BitPilot77's Avatar
I do understand that but is a big cam the only way to go or will a slightly smaller cam work , I'm new to the ls1 , last car had a built tpi m6 480/488 cam . worked good
Old Aug 21, 2018 | 05:31 PM
Lots of people absolutley fly on smaller cams.
I don't consider a v2 a small cam nor a big cam. I know my buddy loved that cam and his car drove damn nice in a m6 and moved pretty good. His car peaked at 6300 rpms with that cam.
I chose a big cam because my end game is hopefully around 10.5 @ 125mph + at close to full weight n/a.
A big cam is not ideal for everyone.
Old Aug 21, 2018 | 08:57 PM
jaxcam02's Avatar
I kinda need to clarify I think. I'm not saying that v2 is bucking like a horse or anything but it's a cam made for high revs. It's not a terrible surge but in a parking lot if you let off the gas real quick you get that drivetrain lash back and forth. And I just stopped cruising on the highway below 1500 rpms. You get used to it and basically relearn how to drive your car. Any internal mods you make are going to change the driveability and take time to relearn the cars tendencies.
Old Aug 22, 2018 | 09:28 AM
Platinum WS6's Avatar
While I don't daily drive my car I would have no problem doing it with the Vengeance VR-5 cam. Its a big cam but with the 6 speed its only different driving really slow in parking lots and what not but a rear gear of 3.73 or higher helps a lot. Looking back I might have gone 4.10s but I wasn't a fan of shifting so often. Anyway as jaxcam02 said, you learn to drive it differently and for the record my wife drives it around town all the time and it didn't take her long to learn how to drive it.
Old Aug 22, 2018 | 09:48 PM
poltergeist 02's Avatar
My old setup was...
LS1 & 4L60E in a 02 Firebird
90mm throttle body
Fast 92
Tick performance SNS stage 3 cam
Morel 5206 lifters
799 heads milled .030 and bowl worked
.040 head gaskets
ARH 1 3/4 stepped to 1 7/8
11/32 pushrods
38lb injectors
racetronix fuel pump
ATI damper
Circle D 3E converter (flashed to 4500)
12 bolt with a 3.73 gear set
LCA’s, short torque arm, PHB
Viking double adjustable front shocks
Cheap competition engineering rear shocks
The car made 454 rwhp and ran a best of 10.84 @ 123mph N/A 800DA
I was running a 26” M/T drag radial with the rear seat removed.
It can be done, just pay attention to detail as you choose parts for your build. Make sure they all complement each other and you have a chance of reaching your goal. If I removed more weight and a little more seat time with that setup I bet I could have went hi 10.6X’s N/A
Old Aug 22, 2018 | 09:56 PM
Originally Posted by poltergeist 02
My old setup was...
90mm throttle body
Fast 92
Morel 5206 lifters
.040 head gaskets
11/32 pushrods
38lb injectors
ATI damper
just curious, how high were you spinning this setup?
Old Aug 22, 2018 | 10:45 PM
My shift points were set to 6900
