Cam for 02 Camaro SS
I want to have a cam installed in my low mileage (43,000) SS, and need a recommendation. The car has BBK shorty ceramic coated headers, an SLP y pipe, and a K & N filter.
I love the sound of a good cam (and of course the added ponies that go with it if done right).
My preference is not to install a stall converter to the stock automatic.
Any suggestions for a great sounding cam/package that won't effect the driveability of the car?
That cam will absolutely not work with the stock converter
LS1Tech Administrator
Received 1,794 Likes
You'll need to pick a priority, or compromise to some degree on all fronts.
With the stock converter, your options are basically limited to the truck/mild cams. Cam Motion has a few. The Summit "Ghost cam" would probably work as well.
However, I do agree with 98CayenneT/A that you should just get a converter, or do both. The really good performance cams will require a higher stall. They will also have that "I'm cammed" sound that you are looking for.
While I am very grateful for the responses, I recently took a test ride in a cammed Silverado with a Yank 3000 converter, and was very disappointed in how abruptly it shifts from stock. I know that is the stalls intent, but not what I really want. The wifey would never ride in it again. So yes, I do need a compromise.
Individual tolerance levels will certainly vary, but a Yank 3000 is a mild converter by LS1 standards. I had a Yank 3500 in my Trans Am before doing any engine modifications at all, and it basically felt like stock after about a week of driving. Honestly, I barely even knew it was there until I went WOT.
If the changes in driveability from a good quality (such as Yank) 3000 stall speed are too much for you, then I would definitely recommend that you stay away from any big lumpy cam choices (especially if you plan to keep the stock stall speed) - I don't think you'd be happy with how the car would behave.
Something like a 228R and the Circle D 278mm HP converter sound right up your alley OP. You need a converter (due to cam overlap) but dont want the attributes of a small diameter big stall speed verter. The HP series is basically that.
Abrupt shifting is not a characteristic of a higher stall speed of a converter. A higher converter will actually shift smoother due to the shift extensions being higher.
The abrupt shift feel is due to how the transmission itself is setup.
Shift kit, separator plate feed holes drilled out to larger sizes, different spring and washer setups in the accumulaters, boost valve, line pressure adjustments in the tune ect
First things first if you're looking for a actual performance gain .....get the mods it takes to make it work. Shorties don't cut it. Do some good bolt ons first. If you think the thought added ponies always make you faster your wrong.
Make it run 11s before you cam it.....atleast very bottom 12s. You'll be happier in the end.
I agree with everyone here. You may have to get a 3000 stall converter at minimum for any choppy sounding cam...
