Frame rail cooler locations
ive been looking at possible locations for mounting a frame rail cooler for power steering and came across pictures of them behind the air dam. Is that location really effective for getting good air flow? Ive seen a picture with a hole cut in the air dam and without a hole. where is everyone mounting frame rail coolers? and what are the pros and cons of cutting a hole in the air dam? This is for a 4th gen camaro.
I've seen a picture of one mounted behind the air damn and a hole cut in front of it. They had smaller coolers and therefore a not so large hole. Im wondering if there is any cooling or aerodynamic issue with cutting a hole in the air damn. My cooler is much larger. its a Derale 13224 and at 21" for the cooling section it would need a much larger hole in the air damn than the ones ive seen cut. that's why i was wondering if there are other places a frame rail cooler can be mounted on these cars.
what kind of connector did you use for the hose? doesn't look like the one that came with it
been running that way for 3+ years
you say the coolant is 180-220ish, are you saying the temps from that location are definitely lower than that? I would say it has to be lower than that. There is only power steering fluid running thru it (and not being "flowed" thru the engine coolant). I have never taken a temperature reading though
The fittings on the end are ones I used that I had laying around. They are "barbed" ones that I had in my misc stash of crap that converted to "an type". Those connecters are -6an female to barb. The ones that the kit came with will work just fine though and just clamp your lines on. I have zero leaks and have had zero problems.
