New to 4th gen camaros
Well y'all I know the LS engines very well rebuilt a couple but what I'm new to is the 4th gen chassis I just bought as a daily, what are some recommendations for me to do to the chassis and this is what I already have...
I got Solid motor mount
-aftermarket torque arm and DS loop
-aftermarket rear control arms
-aftermarket lower panhard bar
-aftermarket locking diff cover
-it's got long tubes
-hurst shifter
-gt grant steering wheel
-all new poly bushings
-aftermarket shock tower brace
-twin disk mantic clutch
-new power steering rack
-cts-v brakes in the front
The car has 78k miles is ther anything else y'all would recommend doing that'll make this car drive a lot better or stiffer.
And any exhaust recommendations was thinking about the speed engineering true duals with the upper panhard relocation!
Thanks for any recommendations ?
-hurst shifter
Sounds like a fun car with some nice upgrades. Any pictures? You didn’t mention some of the standard bolt-ons aka a lid, ram air, ported throttle body, under drive pulley.
As far as drivability etc a good spring shock combo will most likely make a huge difference depending what’s on there now.
Originally Posted by Bspeck82
ya not sure what the previous owner did there. probably rubbing on water pump as well.
lid to maf, maf to couple . Coupler to TB. If what you have is working then I guess leave it. Not sure if that maf is stock though.
Off topic. What was required to get the steering wheel to work.
