Vortec 6.0 initial startup
From: Grew up in Manhattan Kansas, live in Saint Louis
I’m hoping to bounce some ideas off some experts regarding my first start-up on my first build. Engine is on a test stand with accessories on. Oil pressure is good on a mechanical gauge.
The engine has started, but only with throttle and will only idle with throttle. Throttle response felt sluggish, and i couldn’t get it to blip to 3,000rpm. It usually backfired out exhaust as it dies. I was able to get a scan using hp tuners. I’m still pretty new to tuning but i saw my O2’s were at 0-20mV the whole time, which I believe is maxed out lean. I checked a spark plug and it was black, so I assumed I had a false lean reading due to one of two things: A) O2 too close to exhaust exit (they were in long tube header collector, nothing after that) or B) header not fit tightly against header due to the header hitting the stand. I remedied both of those issues by notching my stand until the headers fit right and clamping a tail pipe extension on my collectors. Reset LT fuel trims, and O2 readings were better (~300-450mV), but then I couldn’t get it to start last time I tried.
I am fairly certain I am fighting a bad battery, which is not helping the starting problem, but I had been able to jump it with my truck up til my last attempt, when even that wouldn’t do it. Is it possible a dead or dying battery could be giving my pcm/sensors trouble due to low voltage?
along with the battery, maybe I have a loose or not connect ground.
Could my lifters not be filling with oil? Will they fill with oil at cranking speed?
My plan is to try a different battery, check for sparks and fuel in each hole, crank motor without sparks or fuel until I see oil in the valve train.
My tune should be close enough to start idle I think. (First try at it though so who knows lol)
Is there anything else I need to check? Any help would be appreciated.
engine:
6.0 .005 over w/ 4” stroke for a 403
236/244 112+3 @.050 Camshaft
Trickflow 225 cathedral heads
johnson hydraulic roller lifters
11.38 static compression
8.3-8.5ish dynamic CR can’t remember atm
93 oct fuel
340lph pump
60lb injectors
60 psi fuel on the regulator (after the rails)
fast lsxrt102 intake w/ 102 throttle body
stock 78mm maf
when it started i had 50-70kpa on the map with throttle cracked just enough to stay lit
engine:
93 oct fuel
340lph pump
60lb injectors
stock 78mm maf
Here are 3 scans of the engine - one with the above tune, two scans with some fuel added during cranking. I am starting to wonder if I am having an electrical issue. It wont start most of the time, and when it does, something seems to either cut fuel or retard the spark - you can see the rpm drop despite me holding the throttle +20% open. I didn't see any knock codes, just the EGR low voltage. I did verify that lifters are full of oil, and that each plug was sparking. I did notice after a while that 5/8 header tubes were hot to touch, while the other three were merely warm. 1, 2, and either 3 or 4 were warm while the others were almost too hot to touch.
As an update: I had plugs that were fouled - it looked like potentially oil fouled so I ran a compression test to rule out rings or head gasket. Every cylinder compressed to between 187 and 205 psi. I also get black smoke, not blue smoke so probably not oil fouled plugs. I used a noid light to check for pulses at the injectors, all of them pulsed. I cleaned the spark plugs to try again today. Removed the air filter because it looked dirty. When I did the scan during crank and very brief fire, I got knock retard. I don't know why it wasn't showing before, but you can see the KR go up and spark drop in the scan log. I tried taking timing out (not 100% sure if I was in the right table or not) but it didn't seem to make any difference. I took as much as 7 degrees of timing out before I decided to punt for the night and see if I could find any information online. Plugs look rich, but they should be rich during cold start so I don't know if that's a problem or not. Plugs in order of which cylinder they came out of. At this point my only idea is to try a gallon of octane booster or race fuel just to see if they eliminates the knock retard.
