Problems? Thowing codes?
Ok, wrecked the car last week and it started acting like it was going to die at idle and then it picks back up.
I went to azone after a disheartening dyno and found that im throwing cods p0155 (s1 b2) , p0135 (S1B1) . At first i was asumming that these were from me having no back 02s but the piece of paper that printed out says this
the pcm has determined the the malfunction exist in the heater cirucit for 02 sensor 1 b 1 (02 sensor 1 is closest to the cylinder head before the cats, while o2 sensor 3 and 4 are located further downstreem and are typically mounted in or after the cats
At this point im confused about which 02s are messing up the fronts or the backs, i expeced the back like i said but it looks like the paper is saying its the fronts?
Also have code p0102 which says it means
the pcm has determined that the maf input is lower than expected for the current engine operating condistions?
Im am about to check my maf to see if its ok, what else could it be?
Also during the wreck it pulled the wires out of my 02 ext. but i put them back in no problem. I am going to borrow my buddys tonight and see if thats the problem. I already changed 02 sensors and taht didnt help.
