Fast toys ram air vs free ram air?
^ I just did the FRA mod yesterday, and found that above 60 m.p.h., the car really seems to rip to 100 a lot quicker (didn't go past that). Now it may have been a mentality thing, but it really did seem quicker to 100. What's your opinion on the FRA. Same effect for the most part? People told me it was worth the work, and I'll see Friday night if it helps any. I just have a feeling that my trap speeds are gonna be a little higher.
Well I plan on doing the BG Ram Air kit to utilize my hood nostrils, so I'll basically have the SSRA or FTRA effect, just goind straight into my hood/intake instead of under the car and up into the intake. Hopefully my FRA combined with the BGRA will be a pretty nice combo. After all that and smooth bellows, I plan on getting the LS6 intake to complete my induction mods.
that's awesome, but i doubt the regular guy can make that if it took your father who's got years of experience in metal fabrication....5-6 hours.
once again, that looks great.
If you don't have a lid or K&N, you can get a bundle deal from Tbyrne for like $220 for all of it. I got that and love it. It's the SLP CAI, but it's basically identical to FTRA.
I still don’t plan on making them to sell right now though. I got the idea from the FTRA from a picture I seen online. But I think this one is different. I made the opening at the bottom a little longer & opened it up to grab more air. I think the FTRA stays the same width all the way down to the cars support for the front bumper. Mine is aluminum there’s stainless steel I think. And the air opening doesn’t look centered inside the air box on their pic (maybe camera angel?) I made this one maximize the whole space possible in the air box. Then I tucked the lower back aluminum peace behind the air dam to make it look better & less recognizable
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I still have some of the measurements written down but not all of them. I can try to make a drawing of the three parts and anyone interested can use it as a guide of sorts if they want to make their own?
![Werd](https://ls1tech.com/forums/images/smilies2/werd.gif)
Do a How-To. Constrictor or JmX could host it.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#32
FTRA went on my T/A about 4 months ago. It feels much better (over my cut-out aribox) as I accelerate ... the faster the better. There is one drawback if you live in a hot climate like here in Florida. FTRA instructions tell you specifically that it may cause your engine to run hotter than usual.
I also have the 160 degree thermostat. It runs below the middle mark on my temp guage, except on the hottest days (above 90 degrees). On these hottest days or in heavy traffic, you will need a thermostat that is not the stock one IF you hotrod around town alot like I do. I know it's not my stock thermostat because I put the factory stock one back in and it ran even hotter. Immediately went back to the aftermarket.
#34
I'm a little confused here. Before I did the FRA mod, people were tellin' me it's totally worth it, etc, and now I'm reading posts that it isn't. Dammit. Why do I have all the luck...
#35
FRA ... cutting out the bottom panels from the bottom of your air box. It was a great mod ... pulls air from within the engine compartment and between the radiator and cooler (from the bottom). You have to cut a strip of plastic away from the housing that fits over the radiator there.
FTRA ... stands for Fast Toys Ram Air. It's an air duct that is made by FAST TOYS, Inc. ... generally from stainless steel sheet metal. It's better than the FRA because of several reasons. One reason is that it fits to seal the air box so that you have air pulled up from the bottom of the car only ... and it flows directly into the intake because the air box is sealed. As you go faster, it sorta' forces air into the intake. The results are often overstated, but, itis a dfference that's worth the money ... IMHO.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#37
Logic, man that thing kicks ***. You could definaly make some money off of those. If the price is right, I would buy one myself. I would seriously consider making those for some extra cash.
#38
Originally Posted by Tweety2
Sweet. Now to come up with something that uses the Nostrils and the bottom.
#39
Originally Posted by TransAm52804
That's kinda what I want to do. I already did the FRA, and I plan on getting the BGRA for my hood nostrils, so in a way I will have both; but to make it more effective I'll eventually buy a cheap FTRA or SSRA to go along with my BGRA.
