questions on quarter mile times for 98 ls1
Your MPH is terrible. The only reason you got a 13.5 was your terrific launch on street tires. If you would have had a 2.2 60' (which is common for guys new to the track) you would have been somewhere around 14.0 @ 100.
What was the track elevation? How hot and humid was it when you ran? On a 90 degree day with a 700 foot elevated track I pulled a 13.5 @ 103.79 with just a lid and catback on a 2.1 60' so I'm thinking your car is a good 3-5 mph under par for trap speed. You may want to have it checked out by a mechanic or LS1 guru.
Good Luck
Good Luck
Originally Posted by Roarin_8
That MPH is very low for those mods. The time only depends on traction but your MPH refects your HP. Are you above or below sealevel? With my auto, I ran a 104.2 and that was with a catback and lid and it was a 99 with 2.73s in Raceway Park NJ.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Originally Posted by ActionJack
I would guess a 3200 stall will shave approx .5+ second off that time.
And you may want to consider a tune after the TC install.
13.5 is a good time in a 98' Trans Am. Also, going from a 3.42 to 3.73 will definitely need drag radials.
Good luck though.![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Good luck though.
STF Veteran
Originally Posted by wrath22
Please help ?!?!?!? i have a 98 trans am with some bolt ons. it has slp airlid, smoothe bellow and an 85mm maf, also an slp y-pipe and corsa exhaust system 3inch. it has only 38,000 miles and is in show condition. i still do many shows but i am aiming ti get back into racing with it as well. my best time was 13.5 at 100.40 and best 60' was 1.98. i have 3:42 gears but am going to 3:73 with a 2200 vigilanti stall as well as kooks headers their y-pipe with magnaflow cats using my exhaust that i have now. also i am getting an intake ls6 high flow. where should i be when all is said and done. thank you for your time ![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
STF Veteran
thank you for the imput man it is really helpfull. i think i;m going to attack this problem with the 3:73gears 3000 to 3200 stall. rear suspension and the rest of the exhaust. my ultimate goal is to be an 11 second street car. but first i need to get in the 12s. first things first right lol
