questions on quarter mile times for 98 ls1
Please help ?!?!?!? i have a 98 trans am with some bolt ons. it has slp airlid, smoothe bellow and an 85mm maf, also an slp y-pipe and corsa exhaust system 3inch. it has only 38,000 miles and is in show condition. i still do many shows but i am aiming ti get back into racing with it as well. my best time was 13.5 at 100.40 and best 60' was 1.98. i have 3:42 gears but am going to 3:73 with a 2200 vigilanti stall as well as kooks headers their y-pipe with magnaflow cats using my exhaust that i have now. also i am getting an intake ls6 high flow. where should i be when all is said and done. thank you for your time
-Todd
For your A4 with a 2200 stall and the other mods you are looking at, I'd say 12.8-12.9. A higher stall would put you mid twelves. If the rear is stock you probably have 3.23's or 2.73's
Oh yes, let there be traction.
What the hell? 13.5?? i got an 01 ls1 automatic had 45,000 miles on it all i had was borla cat back and a K&n and i ran a 13.1? maybe i got a good runn' motor... ive also seen a 02 t/a run 12.9 bone stock!!!! with street tires....
-Todd
Altitude can also come into play. Also the track. Weather, humidity, etc etc. At the nicer track of colorado (bandimere, 5400ft) most TAs are only running mid to low 14s. The really shitty track in colorado (PMI, 5000ft) most TAs are running mid to high 14s. It truly makes me sad...but I suppose its not too bad, because the other cars are slower too. But I hate having a 14 sec car!
Originally Posted by transamws686
it is driver as well, how was your reaction tip, did you spin, I even know people who get gas shy and let go a bit.
Originally Posted by Gloveperson
With traction and a stall, I expect much better than just high 12's. Just look at my signature. Imagine if I had LT's...
-Todd
-Todd
ty for the reply. i have heard many different opinions on why i am seeing the times that i am. i think the best thing to do is get different gears and maybe 3200 stall. headers should help as well as the intake by f.a.s.t. where do u thinkk i will be after that stuff is done i am hoping for low 12
-Todd
And you may want to consider a tune after the TC install.
13.5 is a good time in a 98' Trans Am. Also, going from a 3.42 to 3.73 will definitely need drag radials.
Good luck though.
your mph sucks... the time isnt too bad, though some cars do better. What was your 60'?
I dont think you will be satisfied with a 2200 stall... get something around 3000ish, and you will definitely see a more significant difference. with the LT's and gears, and traction I would say mid 12's...
