UMI Short Shifter Handle
Just got it today and installed the bastard on my car...
Gotta say, this thing freakin ROCKS. Shifts are soooooo ridiculously short now, really worth it.
At only $20 bucks, no one with an M6 should be without it!!
Originally Posted by 01formula6
Does this shifter let in extra noise from the transmission like some of the other short throw shifters?
not like i could hear it over the cam,headers ory pipe to cutout, or the hum from the 9" or the vibration from the solid mount spohn tq arm.....
i guess some people just like noise
Originally Posted by Brandon
is it angled any closer to the driver?
i want to put a Short throw on my hurst, but dont want it angled any....
In fact heres a pic of what it looks like.
All u get is a the handle, 2 bolts and 2 washers, so u can see the angle of the handle as it attached to the shifter:
Originally Posted by hitmeoff
Actually, I think it does. Ive noticed alot more noises lately, but it could also be my clutch goin...for the last week or so I havent been able to chirp
It's not mine! woo hoo!
Originally Posted by 2w0s060
Its impossible for just that handle that make any road noise, the ONLY way it could is if your boot was not installed correctly and you have alittle noise coming through there. Otherwise the handle itself has no way to increase noise.
Oh well... another happy UMI handle customer here too
Originally Posted by DMNSPD
The only way it could is the factory hanlde has a rubbler insolator in it. It would be so minimal that I can't believe anyone would complain about it.
i have the B&M and I just cut the stick that came with it down by 1". I think it may have messed up the geometry of it or something because it is harder to shift and feels like Im having to pull it back farther. If I had it to do over again I would have cut it 1/2". The B&M handle acyually curves toward you and then back straight up. I think its curved too much toward the driver.
Its not just noise, but vibration when you put your hand on the **** with aftermarket shifters. Stock shifters are like butter compared to mine.
To install this shifter handle do we first unscrew the shifter ****, pull out the leather shifter boot, remove the two bolts, remove the old shifter handle - and then do everything again in reverse using the new shifter handle?
I checked Install University (Transmission category) and they describe removing the whole center console and screwing around with the parking brake handle. Doesn't this seem like overkill for a shifter handle swap...?
The write-up on Install University is about replacing the whole shifter. All you should have to do to change the handle on the stock shifter is take the leather boot off.
But yea, take off the ****, the boot, take off the original handle, then go back, put the new handle on, the bolts, the boot, and finally the ****.
Originally Posted by my99Z/28
where do i get this umi shifter handle??
https://ls1tech.com/forums/showthrea...&highlight=umi
or...
www.umiperformance.com
