catch can
Old Oct 15, 2004 | 02:34 PM
svenh44's Avatar
Default catch can
Were can i get one of these, i see a few people are using them, please included the website if you have i
Old Oct 15, 2004 | 03:52 PM
CRAGER's Avatar
Administrator
Accurate Machine Works The link is to the right. ---->
I have one on both of my cars, it works great!
Peace,
Craig.
Old Oct 15, 2004 | 04:23 PM
Z28Venom's Avatar
Yes... very high quality piece..
Old Oct 15, 2004 | 04:27 PM
Ravenous T\A's Avatar
Yea awesome piece of work, almost looks factory if you get a black one or a silver one
Old Oct 15, 2004 | 08:03 PM
msbz_ls1's Avatar
what is a Catch Can???
Old Oct 15, 2004 | 08:13 PM
RA122624's Avatar
PCV Catch Cans
AMW PCV Catch Cans are designed by automotive enthusiasts for those who expect a higher standard of performance from their vehicle and wish to help extend the life of their engine by decreasing oil contamination from the intake tract to the combustion chamber. Months of research and testing has provided AMW with a unique and functional kit that has worked flawlessly on many makes of vehicles, from turbo applications, imports, late model domestics, to early model muscle. The internal design of the AMW catch can is superior in function to other catch cans on the market. Oil vapors and other contaminates are first caught and condensed by a stainless mesh and then dropped to the bottom of the can where a series of under-cuts in the walls prevent the oil from climbing back to the top and exiting back into the intake tract.
Oil contamination derives from the positive crankcase ventilation valve common on most internal combustion engines where vacuum is pulled on the crankcase by the intake or in some cases the throttle body. This contamination occurs when oil vapors exit the crankcase via the PCV valve, enter the intake tract, and create adverse effects such as carbon build-up on valves, pistons, and plugs, as well as cause harmful detonation. Detonation in many cases causes the ECM/PCM to retard timing, thus creating a reduction in horsepower. Power adders such as turbos, blowers, or nitrous can benefit greatly due to the removal of oil contamination in the combustion process. Poor emissions could also be traced back to high levels of oil residue being burned in the combustion process. By removing this oil, a clean burning engine could help the environment as well as improving the performance of a vehicle.
AWM’s PCV Catch Cans and mounting brackets are made from 6061 billet aluminum and machined cut on CNC machines producing a precise product with a professional appearance. Dimensions of the can are 2 1/2-inch in diameter by 5 3/4-inch tall, therefore making installations in tight spaces more convenient. Installation takes on average 15 to 20 minutes with minimal mechanical knowledge and common household tools. All hardware and accessories are included with purchase i.e. mounting bracket, screws, billet aluminum fittings, hose clamps, and five feet of hose.
From there website.
Old Oct 15, 2004 | 08:18 PM
msbz_ls1's Avatar
so in other words..does this like add performance..or is it just for ***** and giggles lol..
WHAT DOES IT ACTUALLY DO>>IS WHAT I MEAN>>>i mean...does it increase ne thing...or does it just clean ..
Old Oct 15, 2004 | 08:21 PM
RA122624's Avatar
Did you read the article?
"contamination occurs when oil vapors exit the crankcase via the PCV valve, enter the intake tract, and create adverse effects such as carbon build-up on valves, pistons, and plugs, as well as cause harmful detonation. Detonation in many cases causes the ECM/PCM to retard timing, thus creating a reduction in horsepower. Power adders such as turbos, blowers, or nitrous can benefit greatly due to the removal of oil contamination in the combustion process. Poor emissions could also be traced back to high levels of oil residue being burned in the combustion process. By removing this oil, a clean burning engine could help the environment as well as improving the performance of a vehicle."
I don't have a catch can I'm sure it doesn't hurt. If you have a detonation problem then I would say get one or if you have a blower.
Old Oct 15, 2004 | 08:28 PM
msbz_ls1's Avatar
oh ok..i get ya now thx..
Old Oct 15, 2004 | 08:33 PM
RA122624's Avatar
no prob.
Old Oct 15, 2004 | 08:43 PM
Fulton 1's Avatar
The catchcans really do work in many cases. I was one of the first to use the Greddy can several years ago when I was having KR problems and it has worked great for me. Its defintely not just for S&G.
