Warming up the engine?
Anyway, for my question. For my 3000gt, the owner's manual said to let the car warm up until the temp gauge starts to move. This worked out nicely, on cold days it took a little longer, and warmer days a little less time, then I would just keep it under 3k rpm's until operating temp. With the Camaro, it seems to take much longer to start moving, the heater even starts getting a little warm before it moves, it does move eventually though, just seems slow (I know it works, on 98's the temp gauge was functional). I've been letting it run until the idle drops to about 1000rpms, and then keep it under/around 2k rpms until it's in normal operating range, is that long enough? Just wondering what other people do/recommend. I know this seems like a trivial thing, but IMO, it's one of the most important things you can do for the car. Sorry if this has been asked or discussed before, I couldn't find anything about it by searching.
Thanks
I laugh when I see people start a car and start to drive it right away.
Let it warm up! Gotta get rid of the piston slap somehow.
Take it easy on the throttle when it's cold. Remember, the motor may have warmed up but the tranny & rear end are ice cold still.
Also, when you idle your engine, the oil does not get warmed up as quickly. So even if your coolant begins to climb, the oil temp will still be very low. Therefore you need to have the engine under load.
Just keep the rpms under 2000 and use a light foot on the throttle until your engine is warmed up. This is the best way to go. I do this with all of my cars, even if it's -15F outside I won't let the engine idle in the driveway. That's also a good way to get your car stolen when you do that!
LOL
So true... though I am guilty of that in the winter. But at least it is in the garage and I would hear the change in exhaust if it moved.
LOL
As Patman said it......
