Turning off automatic headlights
I tried following a mod on my 01 Z28 for disabling the automatic headlights and it worked except my turn signals wouldn't flash. I tried searching the forums here and came up empty. Anyone fixed this situation before?
Which way did you do it? The easiest way to do it is to pull up the dash and take the sensor out and put a resistor of some sort in there ( used a paper clip) takes not more than 3 minutes and have done it to 10+ LS1's never had a problem with any of them.
3 minutes beat you buy one it should be simple, just jump the conector.
I've never pulled the dash before or have I seen the resistor. Any site that has pics?
I did it the hard way lol.... In my old camaro
I made a fuse w/ wires gong to my asr button which doesnt work since I dont have asr... i just flip the button...
That way its still automatic all other times...
Just take out the t-top, remove the 2 phillips screws from the A-pillar next to the locating hole for the t-top, remove the plastic pillar cover or whatever it's called. Then the dash has clips and you just pry it up with your fingers enough to get to the sensor. Cut the wires and splice them together. It'll complete the circuit and you will now be able to have manual control. Once you see under the dash it's a no brainer. I did this on my old car and my buddies camaro, works perfect. My new car wasn't like that, something about whether or not a car was meant to be sold in Canada or not. US cars don't have auto headlights, Canadian ones do. I read it in the owners manual.
On my TA, I added a sensor from the junkyard to make my TA have auto lights. It was cool for about one day then got annoying. Luckily I added a toggle switch to control it as well as the DRL. SO 2 toggle switches for me. Everything worked fine.
You can find more info here:
http://www.xse.com/leres/ss/drl.html
LS1Tech Administrator
Received 1,492 Likes
Originally Posted by JasonWW
I hate DRLs and auto headlights.
You'll have to go into more detail because I have no idea what you mean.
You know, the idiot light on the dash board that says "brake". It comes on if you have a brake system failure or if you pull up on the E brake handle. When i removed the DRL, auto headlights box, it also disabled this light on my car.
I've never had a brake system failure, but I do use the parking brake everytime I park (6 speed), so I know what light you mean. It shouldn't have anything to do with the DRL/autoheadlights mod.
BTW, what do you mean you removed the auto headlights box?
Did you remove this module?
Your not supposed to, you can just add a toggle switch and wire it into this box to control the DRL's. If you removed it completely, that may have effected your dash light.
Or else the dash LED just burned out.
Yes, I removed the box completely. He gives a warning on that site that it may take out your dash brake light, and it did. He also said for some people it made their hatch button stop working, but it did not affect mine.
Here's a few pics of the sensor. This is my 98 Z28. I DID NOT have to pull off the drivers side a-pillar cover to get to it, only removee the passenger side and popped up the dash panel from that side, you'll be able to get your hand under there very easily to turn it 1/4 turn and pull it out. As you can see in the second pic, plenty of slack! This doesn't affect the headlight usage via the headlight switch in any way! Basically, the auto headlights are now disabled because the pcm will now think that it's bright outside and never turns them on. I don't know exactly what mod you did, but this is the easiest way to disable the auto headlights as was mentioned above. If your blinkers don't flash, odds are the bulbs are burnt. Remember, if the DRL bulbs are out, the blinkers still won't blink. Blinkers and DRLs are not the same. Hopefully this helps...
On my TA I added that light sensor (the dash has a hole for it) then wired a toggle to short the wires out on either side of the switch. That way you can turn it on or off easily. That is very cool to do. I can now wink my DRL lights during the day when another F-body or vette goes by in the other direction. I'm sure they are thinking, "What the Fu??".
While I had the dash pad up I replaced the red LED with a blue one. Looks pretty cool.
You could leave the sensor in place and add a wire tap to short the wires together. Like this style: Then you wouldn't lose the sensor and it is reversable.
Whoops, forgot to mention that in my post. All I did was snip the wires (leave about 2" on each wire from the sensor in case you want to go back to stock). I basically removed the sensor from the circuit and just hardwired the wires together with a butt connector!
connecting these 2 wires together on a camaro, will it disable the headlights from comming on automatically and still have the amber front bumper bulbs lit. or will turn those lights off also.
