how do u replace the foglight bulb on the TA's
I jus wanna kno how to take the bulb out, i believe its the bulb that can be replaced and not the whole fixture. correct me if im wrong
thanx everyone ill give it another try, hopefully this time i wont cut my wrists tryin to reach in. They are 880's. They have 880 lazerblue ones, does anyone kno if they are any good, are they not as bright? they're only 12watts as opposed to regular ones that are 27watts
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
What I'm going to do sometime is upgrade the housings, and that way I can run brighter bulbs. I have heard too many stories about melting the housings to run anything other than stock.
Originally Posted by Xtreme57
or you can try and squeeze your hand in the air duct below the lamp if your hand is small enough. it worked once - good luck
Originally Posted by rookiels1
Aren't the 893's higher wattage? I've heard too many experiences of high watt bulbs melting factory housings to do that.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
finally got to the foglight, its so easy if u turn the headlights on and reach ur hand from the headlight opening after taking off the black cover thats around the headlights
Originally Posted by SmokingWS6
They are 38 watt bulbs with the metal coating on the tip to prevent melting. 894's don't have the tip. I've had 893's for years and they have never melted.
I recomend the switch, they are actually usefull now
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
