Request Part Numbers
Old 07-17-2006, 10:12 AM
  #341
MM98's Avatar
Originally Posted by Paul Bell
So, this rubber flap..........
Man I've searched every part of my catalog & I'm still showing that molding/flap on export models only, Part#10189322... GM calls it a headlamp opening molding.
Old 07-22-2006, 02:47 PM
  #342
camaroz28nbm383's Avatar
gm main bolts part#?
Thanks Josh
Old 07-24-2006, 05:26 PM
  #343
30thz's Avatar
The part circled in red.
Old 07-24-2006, 06:14 PM
  #344
30thz's Avatar
found it
RH 22146933
LH 22146934
Old 07-27-2006, 10:14 AM
  #345
2001NBMZ28's Avatar
Camaro power window switch (2 switches one unit?) - LH for '01? Saw listing for 94-96 only. Thanks!
Edit: found it - 97-02 - 10402842
Old 07-27-2006, 08:29 PM
  #346
Shallow Bay's Avatar
Anybody know the part numbers for the black pieces that are circled in red located on the driver side door?
Old 07-28-2006, 08:53 AM
  #347
LS1GMCTruck's Avatar
Question 1998 Camaro A/C Cycling Switch?
Have a two prong & need the part number for the three prong one that's needed on an LS1 conversion A/C system. It was used on the '98 Camaro's, I believe. One of those things you write down six times & now I can't find it anywhere. Thanks, Gar
Old 07-28-2006, 04:10 PM
  #348
MM98's Avatar
Part#10260336
Part#22664328
Mike
Old 07-28-2006, 06:27 PM
  #349
Thumbs up Thanks Mike!
Thanks Mike...That was quick! Gar
Old 07-29-2006, 12:07 AM
  #350
Originally Posted by MM98
Part#10260336
Mike
Thanks for the fast response!
Old 07-31-2006, 11:30 AM
  #351
georgewa's Avatar
I need an ASR switch for a 98 Z28, anyone know the part number? Thanks......
Old 07-31-2006, 03:59 PM
  #352
I believe the part number is 10273877.
Old 07-31-2006, 05:43 PM
  #353
Sartobuilt's Avatar
2002 camaro W/ LS6 block. Front and rear engine cover gaskets.
Thanks
Old 08-01-2006, 06:25 PM
  #354
MM98's Avatar
Thanks
Frt cover gasket- part# 12574294
Rear cover gasket- part# 12574293
Old 08-02-2006, 08:49 PM
  #355
Question 4L60E Shift Shaft "Kit" Part Number?
I took a my factory 4L60E transmission out of my 1996 GMC C-1500 & sold it, neglecting to first remove the longer shift shaft & nuetral safety switch assembly I later discovered I would need for the 2001 F-Body 4L60E going into the truck. I understand that there is a "Kit" part number for this longer shaft/switch combination as a service kit or retrofit? Would love to have that number! Thanks again, Gar
Old 08-04-2006, 06:00 PM
  #356
MM98's Avatar
The longer shaft kit is part#24210711(128.2mm long)... It doesn't include the switch, the switch is part#24229422.
Mike
Old 08-05-2006, 08:15 AM
  #357
Thumbs up Mucho Gracious Mike!
Thank-You Very Much Mike... This is great to have someone on the board with this capability. Gar
Old 08-14-2006, 09:33 AM
  #358
TAboo's Avatar
I'm looking for a part number for the stock rear axle bump stop for a Firebird Trans Am, non-WS.6. My WS.6 car has Eibach Pro Kit springs and I've had to remove the aluminum spacer between the bump stop and the frame, just to keep the car from constantly hitting the stop, which is now destroyed.
Old 08-14-2006, 10:32 AM
  #359
TRANSAM75's Avatar
Old 08-15-2006, 10:42 PM
  #360
Ferocity02's Avatar
Interior light dimming ****(potentiometer) for 99 Z28.
Quick Reply: Request Part Numbers
