Request Part Numbers
Old 03-31-2007, 12:52 AM
  #461
KillerTA's Avatar
Question
Anyone know the part number for a charcoal (medium) grey spare tire cover for a 97?
and the plastic screws/retainers that hold it down.
What about a charcoal grey leather ebrake handle for a 97 TA?
Old 03-31-2007, 05:51 PM
  #462
1madss's Avatar
I'm looking for the part number for the panel/bezel that the window/lock switches fit into on the drivers side door for a 00 Camaro with ebony interior.
TIA
Old 04-01-2007, 06:30 PM
  #463
SSPerformance's Avatar
i need the part # for a f-body throttle cable with out tc/ or cruise control
Old 04-02-2007, 04:04 PM
  #464
benliles's Avatar
Default '93 Camaro Z28 front parking brake cable
I am looking for the front parking brake/e-brake cable part number for a 1993 Z28 Camaro
Old 04-06-2007, 01:10 AM
  #465
donskii's Avatar
Don't hate, but I looked at the list and couldn't find what I was looking for.
1993 T/A Fog lamp Bulb No.?
Thanks.
Old 04-11-2007, 02:36 PM
  #466
AL-THAWADI's Avatar
ITS great my frinds
Old 04-18-2007, 06:14 PM
  #467
bradl1982's Avatar
I need the part number for the silver and black ss fender emblems for a 98-02 camaro.
Old 04-20-2007, 10:14 PM
  #468
GR33N GoblinM6's Avatar
what is the part # for the Oil Filler Neck? LS1
Old 04-30-2007, 09:24 AM
  #469
drain89's Avatar
I need the pn's for the antenna delete plug as used on early 4th gens or any car with radio delete option.
Old 05-05-2007, 09:32 AM
  #470
fast377's Avatar
LS1 oil filler tube (with o-ring seal) = 12559505
Old 05-11-2007, 08:25 PM
  #471
HotWhipT/A's Avatar
I need a PN for a reverse lock out solonoid on the T-56 tranny. Its for my car in sig
Old 05-13-2007, 08:39 PM
  #472
ghettocruiser's Avatar
Hey guys/gals... I need the part number for the harness for the convertable top switch for a 99 Z28 vert. If the harness even exists.... Im using the switch for a cut out, and I cant find the darn harness...maybe pigtail is a better term... I may have tossed it by accident.
Thanks!
Justin
Old 05-15-2007, 04:54 PM
  #473
SupermanSS's Avatar
T/A Bezel part number
Old 05-21-2007, 03:13 PM
  #474
taws6's Avatar
Default Part number requests
Hi,
I have a black 2001 Trans am WS6,
Many, many, many thanks in advance.
I am looking for:
Lug nut covers, ( pn: 10028614 ? )
DRL housings, ( pn: 12159662 ? (white triangle ones)) LH and RH
Fender vents, ( all four )
Exhaust rubber hanger / isolator
Thanks again,
Paul.
Old 05-29-2007, 07:20 PM
  #475
King Nothing's Avatar
when was the last time someone updated this parts numbers list???? the p/n's are wrong for the coolant pipe and plugs and the ls6 manifold, wonder what else is wrong. 12573572 is what is listed as a ls6 manifold but in gm's database that doesn't come up as a part, the number is 88894339. can we get an update please?????????
Old 05-29-2007, 10:12 PM
  #476
SupermanSS's Avatar
i think the oil pan gasket number is wrong for the LS1
Old 05-30-2007, 05:53 PM
  #477
yeah i took a printed list of the part numbers since i needed that coolant pipe and the plugs and they kept lookin the numbers up and they weren't poppin up . . . damn things weren't even superceeded, they just weren't they're
Old 06-01-2007, 11:14 AM
  #478
Luna's Avatar
I need a part number for the rear axle bump stops. For a '98 Formula if it makes a difference.
Thanks!
Old 06-03-2007, 12:45 AM
  #479
chae's Avatar
Please post the part number for the fog lights relay. Thanks.
EDIT: Nevermind fixed the fog lights
Old 06-08-2007, 03:50 PM
  #480
why don't you guys just call your local GM dealership? you'll get the right part numbers if you do that . . . until someone updates here
Quick Reply: Request Part Numbers
