Request Part Numbers
Old 01-12-2008, 08:08 PM
  #521
Wsteun's Avatar
Got another part.
The little rubber/plastic piece that's on both sides of the engine bay in the front. It's height adjustable and raises/lowers the height of the hood.
Old 01-14-2008, 06:37 PM
  #522
MM98's Avatar
Originally Posted by Wsteun
Got another part.
#10413888
Old 01-19-2008, 04:05 PM
  #523
SpdFrk1990's Avatar
Anyone know the part numbers for the heat shield over the muffler and the one that goes over the axle or all the ones underneath if you have the numbers.
Thanks,
John
Old 01-21-2008, 12:05 PM
  #524
MM98's Avatar
Thanks,
John
Muffler shield # 10239715- availiable
Over axle shield # 10408723- discontinued
Passenger side frt cat shield# 10417743- discontinued
Old 01-21-2008, 02:15 PM
  #525
SpdFrk1990's Avatar
Thanks
Old 01-31-2008, 10:13 AM
  #526
lilbuddy1587's Avatar
Can someone please tell me the part number for the Oil pan to rear cover bolts (long, skinny m6x1.0 bolts) ? Thanks!
Old 01-31-2008, 03:55 PM
  #527
MM98's Avatar
^ Part# 12554990
Old 03-05-2008, 12:07 PM
  #528
SpdFrk1990's Avatar
I need the part number for the driver side bracket that attaches to the headlight and the fog light.
Old 03-05-2008, 10:57 PM
  #529
817Borla's Avatar
whats the part number for 98-02 trans am front bumper cover
Old 03-10-2008, 05:05 PM
  #530
MM98's Avatar
^^ Part#12335523
Old 03-14-2008, 08:04 AM
  #531
ThunderZ28's Avatar
I need the part number for the adjustable bracket for the driver side headlamp.
the one that bolts to the headlamp, and slides onto the headlamp bracket.
Old 03-19-2008, 03:33 PM
  #532
ls1owner4life's Avatar
What is the name of the rear "CAMARO" panel between the bumper cover and rear hatch for a 98+? aka berger
Old 03-19-2008, 05:32 PM
  #533
blk/slvr02ss's Avatar
Filler panel.
Old 03-20-2008, 12:38 AM
  #534
Originally Posted by blk/slvr02ss
Filler panel.
All I found were pontiac tail filler panel part numbers...
Old 03-31-2008, 09:52 AM
  #535
zman1969's Avatar
Default Trans am Turn signal/daytime lights
how about part # for t/signal/daytime running lamp assy guess mine are leaking causing bulbs/sockets to burn up/corrode too easy - looking for lamp assy for Trans ams , allready found # for sockets and bulbs on the list
nice design GM
Old 04-01-2008, 06:12 PM
  #536
Dave 96TA's Avatar
PCV hoses on both sides of PCV valve - 99 Z28.
Old 04-05-2008, 12:05 PM
  #537
deejaydaze's Avatar
I'm looking for the passenger side power window switch bracket. I'm sure this has come up before. Does anyone know the part 3 and if it comes with the 2 clips? I found 10402841 on here but that just says...
Camaro power window switch (94-96), RH = 10402837
Camaro power window switch (2 switches in one unit) (94-96), LH = 10402838
Camaro power window switch (97-02), RH = 10402841
Camaro power window switch (2 switches in one unit) (97-02), LH = 10402842
I got 10288873 from the dealer just now and I don't think that is right. I can't find that part number anywhere.
I don't need the switches, just need the bracket part.
Old 04-14-2008, 06:36 PM
  #538
Kevin01Z28's Avatar
Default 180 Thermostat part #...
Ive done multiple searches and came up with 12571261 which is for 98-02 ls1's but its a 195*. Owner's manual for 01-02s says the 5.7 has a 180. I cant comfirm this. Trying to decide to go with 160 or not. If it does in fact have the 180 than i can get the money back for my slp 160 stat.
Old 04-14-2008, 08:05 PM
  #539
Blksilvr's Avatar
Need part # for a 2000 trans am M6
Tail Extension housing GM
Vent Tube, GM
Housing, Clutch Adapter GM
Transmission Front Adapter (GM)
Old 04-24-2008, 12:44 AM
  #540
wtomlinson's Avatar
need part # 2001 Z-28 A4
bend bracket that holds the bumper and the front fascia together. has the 3 built-in screws on the bottom. drivers side
Quick Reply: Request Part Numbers
