01 T/A problems
What is going on? I'm really considering trading it in for a Charger
I've had bad window motors, rear tail-lights with bad seals, mal-aligned 'vert top, broken power seat, cracked 02 cat sensor, you name it. No problem has been on it for more than a week before I've fixed it myself or with help. When I want dependability, I just drive my wife's Accord. When I want to have fun, I drive my car.
I would never give up on my T/A. It's in good hands.
BTW why didnt you just fix the problem yourself. Not trying to flame you, but are you not that mechanically inclined. If you arent then a T/A is definately not the car for you. Almost any T/A, Camaro owner will tell you they do all the work themselves. Another part of having a muscle car.
well this ******* was going to sudjest you probably got ripped off, this ******* was going to sudjest how you might get some $$$ back, this ******* was going to point out that your TM CANT kill your car unless your block superheated and ceased,and then replacing your TM would not FIX ****, this ******* was going to sudjest a few things to check that might have kept this from becomming a problem later...
but hey..... i'm an *******..... so i wont....
have a nice day with your pile..... another vote for buying a charger....
geez!
Now ya did it...
FYI - jaberwaki is one of the resident jack of all trades and is also helpful.
Oh well.
BTW I think he gave some good advise even if it was what he was "was going to sudjest".
Anyway, what are your suggestions? Also, the gas gauge stopped working. How do I get this fixed? Is it a simple fix or pretty complicated?
and if he told you ......
1. your car died because of a faulty thermistat....
2. told you he FIXED a faulty thermistat(its either broke or it aint... you replace them)
3. charged you more then 75 bucks total to replace it (40-45 for the part, 30 for half an hour labor)
then thats exactly what happened....
the honest truth is i have no clue what so ever how i came across to you... you see the internet sucks when it comes to sarcasm.... i type things exactly the way i would say them to your face.... how you interpet it is on you.... i cant help that...
you see an ******* would have said ....
you cant fix a thermistat you fukin moron, you got hosed because you are an idiot, how bout at least cracking open you owners manual before you let some shadetree greasemonkey give it to you with no lube you *****....
but as you can see i did not say it anything like that... i merely asked a question, and sudjested the proper way to fix a problem with a bad thermistat... you filled in the rest yourself, in your own mind...
i say things direct, i give answers direct... if i can help you i will... and an ******* would never help you after you called him one
ok off the bat it sound like a problem in your electrical system, caused youre
car to "die" i would lean toward a frayed or exposed wire either near your battery, starter, or alternater, because what i think happened is that wire got wet(was it raining?) or it touched the frame killing power and causeing your car to "die" , and when things like this happen it not uncommon to blow a fuse or 2, which might explain your gas guadge not working...
i would also guess that the mechanic you took it to may have found that wire after taking too long to locate the trouble, fixed it with some electrical tape and charged you for a thermistat so he could make up the cost in time it took for him to find what was wronge...
this is just a guess based on vauge info given...
now for your part...
all anyone can do is guess without more info...
try to explain in as great a detail as you can
1. how the car acted as it was dieing, did the guages go nuts? did the car die fast or sputter out... did it lose horse power more then 30 seconds before it died, was it kicking and bucking... did the lights go out too?
2. what was the day like? hot? raining? night time? day time? were you at highway speed or stopped at a light...?
3. after it died did you try to restart it? if so what did the car do? motor turned but no start... motor started but would not stay running... no turning at all just a clicking noise... no noise no turning no nothing at all no power...
thats all i can think to ask now .....
after we figure out what was REALLY wronge, i will tell you how to get some of your cash back
see, i'm not so bad am i?
As for Jaberwaki, ive noticed that he always gives good advice, and help where applicable. Might want to work on his spelling though.
hey man when your brain is as small as mine you only have room for so much stuff...
i chose to fill it with car ****.... i had to leave out spelling and good manners
Now to answer someone else's charge. So work I do myself and other work I'll have the dealership do. I don't have the time nor interest in taking my car apart and trying to access the issues. That's why I have a warranty. Hey, sometimes it's expensive but whatcha gonna do?
