Am i on the right path?
I am starting to plan some mods for my car. Tell me if i am on the right path. I am wanting atleast 400hp at the wheels, tell me what you think about my mods and if they will get me there. hooker longtubes, some kinda true dual setup, 224/224 .563/.563 114 LSA from thunder racing, stage 3 ls6 heads, i already have a lid and all the free mods. Tell me if i am on the right track. What kind of mpg would i be lookin at, I drive pretty resonable until them mustangs need to be straightened out. Oh and i am lookin at a SPEC stage 3 Clutch, would there be a better clutch out there than this? Thanks for any help guys.
do you think the cam i have chosen is to radical? and i have the ls6 intake already. Would you make any changes to what i have already chosen?
the 224 cam is a baby cam... tuning is a sinch,
the only thing i would sudgest is going with the comp xe-r 224/224 581/581 112 lsa...
with a great set of heads, and a open exhaust like you are planning, the higher lift and lower LSA will give you a little more hp up top...
Originally Posted by jrp
personally i'd opt for a set of milled 205's over a stg3 ls6 head with the TR224. the 205's offer the same if not better low and mid lift flow curves, not to mention the port velocity advantage.
its the H/C set up i have in my ride right now....(since i am taking her off the street the cam is about to be changed, but for a daily driver it was awesome)
make sure if you go with these heads that you get cometic head gaskits and send tony momo @ afr a pm for advice on your set up...
Originally Posted by blkZ28spt
Personally, I'd get a bigger cam and do a gear swap. Make 400 rwhp cam only and 430++ rwhp with the heads.
Originally Posted by jaberwaki
that cam with 205 heads will make more then 430 rwhp in a m6..... with a 228 cam tony made 480 hp ....
I can't wait till I can afford to get some new heads myself. Then forged internals. Then nitrous. Then maybe I'll be satisfied.
personally i'd opt for a set of milled 205's over a stg3 ls6 head with the TR224. the 205's offer the same if not better low and mid lift flow curves, not to mention the port velocity advantage. most stg3 ls6 heads are setup for big bore, big cube applications.
Keep in mind guys this is my daily driver and i want to keep it half way driveable but still turn heads in traffic and let people know there have been some stuff done under the hood. But want to be able to hold my own at the track
The mods you listed are deffinately putting you in the right direction. If i were you i would go with the AFR 205's as JRP stated, and i would use the cam that Tony from AFR reccomends with those heads. The 224 cam you listed is a baby cam by today's standards, and the cam Tony at AFR reccomends isn't much (if any) bigger.
