which should i do first??
Old Aug 18, 2005 | 01:10 AM
Z28LS1camaroguy's Avatar
Default which should i do first??
ok i am set on these two setups and i dont know which to do first, should i go with coated pacesetter long tube headers and TSP offroad Y. or should i do the Fuddle racing 3500 stall and 3.73 gears first, help me make my decision and comments on the choices. i am getting a cutout installed right before the muffler so the flowmaster will just be for looks mainly lol.
Old Aug 18, 2005 | 01:50 AM
also do i need the 3 inch cutout or can i fit a 3.5 inch cutout on my flowmaster catback I pipe?
Old Aug 18, 2005 | 03:19 AM
Cop Car's Avatar
what rear gear do you have? if you have 3.23s id say just put a girdle on it and stall it....if you have 2.73s deffinatly get gears, then stall it..
just my .02
Old Aug 18, 2005 | 07:38 AM
Tx02ssm's Avatar
My son just installed 4:10's on his 00 T/A and it is friggin awesome - my next mod will definitely be 4:10 gears with a girdle.......I would suggest you not spend your time/money on 3:73's unless you really care about 130mph+......... And yeah, go with the convo+gears. Changing how your auto shifts makes a huge diff in driver satisfaction/response time to WOT and several other factors that can only be felt by seat-of-the-pants method. I used to own a 99 Lighting, and the best mod I made on that truck was a 60buck valve replacement piece that went into the tranny and changed the shift points - 1st to 2nd would hit like a ton of bricks and I could get a pretty serious chirp 2nd to 3rd after that mod. It added no HP, but made a huge difference in how I felt about the truck off the line. Good luck w/mods - stevet
Old Aug 18, 2005 | 08:00 AM
EPP's Avatar
EPP
Thumbs up
http://www.exoticperformanceplus.com...php?service=66
The above link has a lot of ideas on what should be done for these cars. Bob
Old Aug 18, 2005 | 09:32 AM
BlueSix's Avatar
Go with the converter first.
If you already have 3.23 gears then don't waste your time on doing 3.73's. Take that money and put it somewhere else.
Be sure to get a good tranny cooler.
Old Aug 18, 2005 | 12:36 PM
i have the 2.73 gears unfortunatly and definantly need more power in the rear, want to be able to smoke em all the time lol.
Old Aug 18, 2005 | 03:40 PM
Cop Car's Avatar
Deff stall, cover and 3.73s then...
3.73s really woke up my friends 2.73 car...
Old Aug 18, 2005 | 04:19 PM
jaberwaki's Avatar
stall and gears(everyone already said) and you want a 3" cutout not 3.5
Old Aug 18, 2005 | 04:49 PM
blkZ28spt's Avatar
According to your sig you already have both.
For a purely performance gain get the converter. Converter, shift kit, trans cooler, trans temp gauge, some basic PCM editing of shift points, subframe connectors and drag radials. Will be a night and day difference.
The gears are not nearly as important as the converter, so if you can't get the gears yet don't sweat it as they won't net more than anyway 0.15.
I did my headers/duals before converter cause I was all about the awsome sound, but the converter is a much bigger SOTP difference.
PS: Where in Indiana are you located?
Old Aug 18, 2005 | 07:30 PM
ULTIMATEORANGESS's Avatar
i went with a TC and gears before LTs.
Old Aug 19, 2005 | 12:27 AM
ok well i think i will get the fuddle torque converter and GM 3.73 gears first and then go with the exhaust mods. also how much does it cost to get the converter and gears installed??
