Fuel Rail Covers, Why?
Corvette-style fuel rail covers look pretty cool, but I would think they hold heat in. Wouldn't you want heat to radiate off the engine?
I'm sure there is a reason other than aesthetics (sp?), but I don't know what it is. Anyone?
No other reason than making it look good. I don't think the holding heat in works too well. I mean the Hood is only a few inches above that. Heat doesn't go through the hood. The cooling takes place internally via coolant.
Not to hijack this thread but has anyone ever filled in the corvette letters with some kind of filler and then repainted them? I like the covers but i don't like putting something that says corvette on my car when its not a corvette. Or is there aftermarket ones that don't say anything?
How many would be interested in a carbon fiber type fuel cover with the name of their car on the cover and cleared over?
I have a LS1 Rx7 and I was thinking about getting a carbon fiber fuel cover with the name LS1 Rx7 in red on the cover and cleared over it.
You can buy custom aftermarket frc's from afterthoughtsauto.com They are a sponser here check them out, they start at $195, they already have the holes cut for the f-body fuel lins and they can be painted to match your car for only $35 more....
After thoughts auto
After thoughts auto
Just curious, does the older 97-98 Corvette fuel covers a direct bolt on to the F-bodies? I saw that on afterthoughtsautos.com that theirs look like the 97-98 Corvette fuel covers that already have the dual fuel lines cut.
Just curious if anyone can confirm that. Also, I bet I can get some fuel cover made of Carbon fiber for around $350 a set and maybe additional letter for each individual car for around $50 plus. I believe this guy will even clear the fuel covers over the letter, so it looks like it flows better and will last longer. I really want to get me a set that says LS1 Rx7, would be awesome.
What rock have you been hiding under?!?!
Go to the Appearance forum, or use the 'Search' function, you'll find a ton of information available here on this site.
And the #1 reason people use them is simply for 'appearance', ...
But if they were a real problem & 'held in' heat, ..., would GM really continue to use them?!?
And Carbon Fiber units are available from the after market already also.
