Learning stick
These cars are easy to get going from the start. To me the toughest thing to do is get it smooth into second gear when just driving normal. Sometimes it ends up being a tad bit jerky.
In my opinion though there is just something cool about driving a car that not everyone would know how to drive....let alone drive good. And a chick that can drive stick......oh man, that equals total hotness!!
I got an A4 Camaro and kinda wish I had a M6....so I'm looking for an M6 Fbod.
The biggest one is when upshifting, I pretty well understand to back off the throttle just a little, but I've also heard to totally release the throttle as the clutch goes in, and not to bring the throttle back until the clutch is coming out. I've found it to be way smoother just to hold the throttle constant while the clutch is in. Is one way safer/better for the clutch, or is this just a user preference?
Another thing that I'm wondering about is how to skip a gear. Say I wanted to go from 1st to 3rd or 4th, do I need to add throttle up to do this, and how much? I'd just go and try it for my self, but I cringe everytime I do a shift and hear the tires lock/chirp.
Just looking to get some information to get me started with so I don't do any absolutely unnecessary damage.
Thanks a lot guys,
Ross
Thanks a lot guys,
Ross
Driving a stick isn't really one of those things you can learn by reading about it, you have to get out there and do it (mistakes and all)
It stalled out on me 3 time's on the way home.
If you're hearing the tires chirp and lock, there is something wrong, they shouldn't be chirping unless you're really into the throttle, and quick shifting(or power shifting), are you sure you're going up 1-3 not 3-2
Best thing to do is practice, you aren't likely to smoke the clutch (they are pretty good for a stocker) you'll take a few thousand miles off the life, but being new to a manual that's to be expected.
Thanks
Now to really learn to drive an M6, I'd find a deserted parking lot, and just go practice starting off, in about an hour you'll be doing pretty good, and after a week living with the car and driving it, you'll be just fine.
Mine is the first manual since 87, it took about 15 min to get accustomed to the clutch, then about a week to get totally comfortable with it
Maybe I need to get her one.
Guess what? Now I have an A4 and I wouldn't have it any other way
I'm lazy
I am going to let my girlfriend learn how to drive a stick in my SS so I can have an excuse to upgrade the clutch.....not till I can afford it will she learn though
Sometimes, I like driving around using nothing but 1st and 5th/6th... since pushing 1st is enough to be speeding on lots of city streets anyway. One thing I've learned is that your shifter will be easier to drop into whatever gear when the engine gets around the correct RPM... so to help you figure out what the right RPMs are for a proper shift, you could just push lightly on the shifter with the clutch disengaged, watch the RPM dropping (keep an eye on the road!), and see when the shifter "falls" into place. Takes a little experimenting to find the right amount of pressure, though. 1500-2200 clutch drop launches you into next week
around town off idle at like 1300+- shift into second at 3000
