What next
If you have the hurst/slp shifter (you could get as an option) try the UMI short stick, I bought a used stock hurst, and the short stick, and that (for me) is the perfect combo, no need to go spending $150 on a pro 5.0, ripper, etc, give it a try, you might like it (even if you have to buy a stock hurst first, it's still cheaper than the others, if you get the shifter used)
kevin, good luck with the hurricane, i hope you guys fair well.
I doubt it will be that bad. It will probably hit further south down near Tampa.
The Navy is sending 3 ships down there, and even though i was just in New Orleans for a month, im thinking of volunteering to go on one of those ships If you have the hurst/slp shifter (you could get as an option) try the UMI short stick, I bought a used stock hurst, and the short stick, and that (for me) is the perfect combo, no need to go spending $150 on a pro 5.0, ripper, etc, give it a try, you might like it (even if you have to buy a stock hurst first, it's still cheaper than the others, if you get the shifter used)
