Performance
Old Dec 27, 2005 | 09:57 PM
DSRCAM's Avatar
Default Performance
yea i was wondering if i put on headers,3.73 gears,2400 stall converter,SLP loudmouth exhaust, and SLP Air induction intake. More less how fast will i be 1/4 and street wise!
Old Dec 27, 2005 | 09:58 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Mid/high 12's @ 110mph. My wide open guess.
Old Dec 27, 2005 | 10:01 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Probably anywhere from 12.5 to 13.5 depending on skill, traction (tires), and your particular car (model year, health of the motor, etc.).
Old Dec 27, 2005 | 10:02 PM
DSRCAM's Avatar
if not what do u suggest i should do to get a lil faster?
Old Dec 27, 2005 | 10:03 PM
!LS1 11 Second Club
Cam or Nitrous.
RPM WS6's Avatar
BIGGER STALL. 2400 is a waste for an LS1. 3500 or bigger should be manditory.
Old Dec 27, 2005 | 10:06 PM
DSRCAM's Avatar
how much of a car length will i gain with a 3500 stall??
Old Dec 27, 2005 | 10:10 PM
RPM WS6's Avatar
Gain over what? Over stock? Not sure on car lenghts, but if you do nothing but add a 3500 stall and some sticky tires, you should drop a good .5 sec. or more off your ET.
Old Dec 27, 2005 | 10:12 PM
DSRCAM's Avatar
thanks
Old Dec 27, 2005 | 10:19 PM
RPM WS6's Avatar
thanks
I'd suggest to spend some time in the auto trans section researching which stall is best for you. There are quite a few brands, and many stall speeds to choose from (however I would recommend you skip any stall lower than 3500) to fit various bugets and goals.
What I can tell you is, just about everyone (planning to drag race) that goes with a stall lower than 3500 will regret it and want more later. Keep that in mind when picking your setup.
Good luck.
Old Dec 27, 2005 | 10:40 PM
Stone0fFire's Avatar
i came here because youre a newbie in need of help.
how did i know?
two things= "2400 stall" and "SLP" i dont know which is worse
but the loudmouth is all-right
our torque peak is around 4400rpm.
the closer your stall speed is to your torque peak,
the faster you'll be.
get it as loose as you can tolerate.
test drive our cars to find out how much stall you're willing to put up with.
unless youre building it up for street racing..
then you might want to limit your STR
high-stall on the street = driving sideways
Old Dec 28, 2005 | 05:35 AM
RPM WS6's Avatar
how did i know?
I agree that 2400 stall and LS1 motor do not belong together, but there is nothing wrong with SLP in general. They have some great products, only thing I don't care for from them are their LS1 F-body headers.
