99ls1 v 01 ls1?
Old 05-17-2006, 04:49 PM
staringback05's Avatar
Default 99ls1 v 01 ls1?
ive got a 99 TA thats getting a new engine, my warranty company sent a 99 rebuilt motor that my mechanic checked out and said was garbage...metal in the pan....soooo the warranty company decided to send me a 01 ls1...im just wondering what the differences are between the two motors?....intake manifold? egr, air, etc etc
Old 05-17-2006, 05:53 PM
Blk97WS6's Avatar
the 01s came with the LS6 intake manifold
Old 05-17-2006, 06:38 PM
'Trust''s Avatar
LS6 manifold, slightly better oil distribution, LS6 oil pump, no EGR, and I believe the 01's have 28lb injectors too, I kn ow the 98's and 02's did.
Old 05-17-2006, 06:55 PM
Moderator
davered00ss's Avatar
LS6 intake manifold, 241 casting heads, No EGR,
Old 05-17-2006, 06:56 PM
Moderator
oh, and a smaller cam.
Old 05-17-2006, 07:30 PM
FL01SS's Avatar
They did have the 28lb injectors.
Old 05-17-2006, 07:44 PM
'Trust''s Avatar
Thanks FL01SS Oh, I forgot about the 241's
Old 05-17-2006, 08:43 PM
whats the difference on the castings?.....im getting to keep my old engine...the 99 stocker, spun bearings...but everything else is fine....so i come out of this, paying 350 bucks, getting a 01 in the car and a 99 on a jack, warranty company pays out 6400 bucks
Old 05-17-2006, 08:49 PM
'Trust''s Avatar
853's (99 - 00 heads, although some late 00 got the 241's) flow a little less and are also limited more for port work, avg. gains switching from a straight cast 853 to 241, 8-10 RWHP.
Old 05-17-2006, 08:53 PM
also when i was with my mechanic looking at my engine...there wasnt an AIR pump...do those not come on 99s?
Old 05-17-2006, 09:09 PM
'Trust''s Avatar
They do, although it is located inside the bumper, i doubt it would have been removed from the car.
Old 05-17-2006, 09:18 PM
duh, didnt think of that....the no egr on that 01 sounds nice though....and that ls6 intake saves me $350....im thinkin about cnc my old heads off the 99 and porting the tb....maybe selling or stroking the block...i havent decided yet
Old 05-17-2006, 09:22 PM
'Trust''s Avatar
I'd cnc the newer heads, the 853's are alot more limited than the 241's, and building a stroker/back up block is a good idea if you plan on modding up quite a bit. For reference, my heads are just stage II 241's and then I have a tr224 .563 112, and made the power in the sig through a stalled auto, not bad for mild heads.
Old 05-17-2006, 10:26 PM
i see.....ill prolly go with a low stall, a zo6, or cheatr cam, and full exhaust....that should put me easily at 400 rwhp....thats my goal....this new motor will save me a good amount of money with those heads and that manifold.....i just got a cutout that im gonna add to the stuff in my sig....im thinkin 315-320 after that....mechanic said with that old motor and just the lid and tb port, i was making around 295 rwhp becuase of the a4
Old 05-17-2006, 10:40 PM
'Trust''s Avatar
cheaTR cam and bolt ons you'll break 400, you'll need quite a bit more to do it with the LS6 cam, its not too aggressive, and wont show more than probably 350 with boltons through an A4
Old 05-17-2006, 10:58 PM
i just want it driveable, streetable whatever....i want something that will hold idle and not give me problems...i felt one of those two would be the way to go....i know everything works together...but just to be dumb, headers and straight pipe is about 30hp all together, lid port tb and manifold 20-30, tune 10-15, cam and heads around 50....i think those are pretty conservative numbers, like i said i know they all rely on each other but thats a guess
Old 05-20-2006, 11:28 AM
drohm6's Avatar
Default Forgot One Thing
pump, the 01 is going to be set up for a air pump for emitions, the 99 wont have one, it will not pass a echeck anymore
Old 05-20-2006, 11:40 AM
ehhh thats the joy of being in fl. we dont have emissions....someone say open headers?!?! jk
Old 05-20-2006, 11:43 AM
and on the injectors...did the 99 have 26lb or what?
Old 05-20-2006, 11:45 AM
jrp
SN95 Director
jrp's Avatar
yes..
