Which Gas?
Old Jun 18, 2006 | 12:22 PM
SLVR_99-Z's Avatar
Default Which Gas?
If this is in the wrong thread, I'm sorry. I'm new here. On to the question. I just picked up a 99 Z28. Of course it has the LS1. What are you supposed to run for gas in this engine? I assume premium (~92 octane here) but most of it around here is labled "non-oxygenated- for collecter vehicles, boats". is this what I should run or should I drop down to super (~90 octane). thanks for the help. sorry so long.
Cliffs notes:
what octane gas? premium says "non-oxygenated"? HELP.
Old Jun 18, 2006 | 12:44 PM
HeapaShifter's Avatar
The best place to look would be the owner's manual if your car came with one.
You should run 93 or 91 depending on what area you live in. (Some states don't have 93.)
Old Jun 18, 2006 | 12:56 PM
SLVR_99-Z's Avatar
didn't really think about that. i currently do not have the owner's manual. it was forgotten with the sale so i need to go pick it up and the soonest i can meet the guy is mon. good idea though. thanks.
Old Jun 18, 2006 | 01:57 PM
blue01ta's Avatar
I run 93 in mine.
Old Jun 18, 2006 | 02:09 PM
chewy99ws6's Avatar
I use 93
Old Jun 18, 2006 | 02:19 PM
00transamnh's Avatar
everyone is going to tell you 93+
have fun with your new f-body
lowchevy2go's Avatar
i also run 93
Old Jun 18, 2006 | 02:20 PM
98 Raptor TA's Avatar
Cliffs notes:
I did some reading up on that non-oxygenated gasoline, and it looks like that is basically "normal" gasonline. Oxygenated gas is what they're starting to use in california and big cities, it burns a little cleaner but supposedly makes your A/F ratio a little leaner. So it looks like the non-oxygenated would be better to run cause it wouldn't lean out your A/F.
Old Jun 18, 2006 | 03:46 PM
SLVR_99-Z's Avatar
thank you very much White95. that is what i was looking for. i knew i was going to hear 93+ from most people, just wasn't sure about the non-oxygenated thing. i guess i should have been more clear on that. thanks to all who replied.
Old Jun 18, 2006 | 04:47 PM
SVThis's Avatar
i run 89 (im cheap)...runs just fine though
Old Jun 18, 2006 | 04:55 PM
freakynipples69's Avatar
no less then 91, 93 if available
Old Jun 18, 2006 | 06:37 PM
DuronClocker's Avatar
I'm running 93 in my car, but my compression is around 11.1 or so. I don't think I ever ran anything less than that before the modding though either.
Old Jun 19, 2006 | 01:09 PM
ChocoTaco369's Avatar
Tech Resident
an LS1 with stock compression requires 91 octane. due to your ECU's fuel tables, it will run poorly/lose power if you put less than 91 octane. however, it will NOT GAIN POWER or run any better OR GAIN FUEL ECONOMY if you put in anything above 91 - THIS IS NOT DEBATABLE, it's science. anything else is a waste of money (unless your car pings on 91 for some reason).
octane is not a power adder. it is a detonation supressor. use 91, it's all it needs. anything else is a waste of money.
