What has gone out in your F-Body?
#42
2001 TA:
@29k when I bought it: torque arm mount, signal flasher
29.00001 miles: driver's side window motor
later: both front signal lamps (filled with water, what a great design)
now at 41k...
-sectari
now at 41k...
-sectari
#44
1998 Z28
Window motors (x2, going on three)
Rear end (posi, ran multiple 1.64 60's before it blew)
3-4 Clutch Pack on stock transmission
TCI SSF Torque converter (x2)
#49
115000, two window motors, two headlight gears, the display light on the stock stereo, two seatbelt brackets(on the passengerside headrest) from people breaking them, stock airbox lid wasn't fitting right after i got the oil changed(they broke it) so i just got an aftermarket one and change the oil myself now, the clearcoat on my hood is also starting to go out
#53
98 Trans Am A4 76,000 miles
(In Order)
1. Water pump - 55,000
2. Rear shocks - 65,000
2. Alternator - 70,000
3. Both window motors - 73,000
4. 1 headlight motor gear - 74,000
5. Front shocks - very soon
(In Order)
#54
'99 Firebird, 57k
-alternator
-tranny
-just about every exterior bulb
Need to replace:
-blown door speaker
-driverside mirror(spring gave out, but have it locked in a usable position)
-alternator
-tranny
Need to replace:
-blown door speaker
#55
Front Rotors at 95,000, Clutch at 95,000, Front 02 sensors 104,000, Front and Rear shocks 95,000, Battery at 93,000....thats it
Oh, I have 109,000 mi. and got my ride in 9/05 w/ 93,000.......None of these went out on me but they were in need of being replaced
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#56
teh PuRpL3z
Formula... blew a speaker, fragged the rear end from doing too many burnouts, warped brake rotors, seized brake caliper.
Trans Am.. only had it a few months, but I'm fixing things the previous owner didn't... clutch is shot, e-brake is kinda fucked up, leaking t-tops, leaking tail light and front turn signal, warped brake rotors.
#57
2000 SS 71K
bewtween 55K and 70K:
alternator
water pump
original owner replaced the battery with an aftermarket and didn't get a mount put in
rear main seal in the transmission
bracket for the rear bake caliper
body control module (if your stereo goes out and turns back on after you hit bumps or at any ole time your BCM might be goin bad)
all speakers
fog light bulbs
brakes
tires
stereo
alternator
water pump
all speakers
fog light bulbs
brakes
tires
stereo
