Double Clutching......
Old 09-25-2006, 09:52 PM
Midnight's Avatar
Whats the advantage of powershifting? If any.
Old 09-25-2006, 10:15 PM
burnzilla's Avatar
Originally Posted by unit213
Nope.
He uses no clutch at all? Yeesh...that's brilliant.
For the simple minded, I guess its alot to conjure.
He did it once to show me that you can go through the gears w/o using the clutch.
Maybe next time I'll explain it more, I guess this isnt enough.
"My father showed me in his 6 Speed Vette. It wasn't until 6th he used the clutch, and he did not grind one gear or hurt the clutch at all".
Old 09-25-2006, 10:19 PM
98 Raptor TA's Avatar
Originally Posted by burnzilla
My father showed me in his 6 Speed Vette. It wasn't until 6th he used the clutch, and he did not grind one gear or hurt the clutch at all.
Right when you let off the gas, the pressure releases and then you firmly shift it into the next gear. Its not as easy as it sounds.
You CAN shift without the clutch but its not good for the drivetrain so i wouldn't advise it. There are many things you CAN do, but that doesn't mean you SHOULD do it.
Old 09-25-2006, 10:26 PM
ebear's Avatar
its not hard to shift clutchless
rev it up to the shift point and pull on the shifter
the gear will pop out if you do it at the right point
now apply a little pressure down on the next gear
once the rpms drop it should suck the shifter right in
Old 09-25-2006, 10:35 PM
ebear's Avatar
the revs don't drop while you shift
Old 09-25-2006, 10:36 PM
ebear's Avatar
I don't even powershift everytime that I race. You should mostly use it when you're FULL-ON racing like at the track or a car that actually stands a chance.
Old 09-25-2006, 11:38 PM
Lucas'02SS's Avatar
You don't have to grind or anything for it to still be hard on it. I mean does it work...yes. No one is denying that. But it IS hard on it. I wouldn't do it in my car.....And I wouldn't get too sarcastic on Unit213...the guy knows his cars. Plus he's a moderator.
Old 09-25-2006, 11:49 PM
darrensls1's Avatar
Unit213 has probably forgotten more about cars then you'll ever know. Calling him simple minded was not only out of line but absolutely absurd.
Old 09-26-2006, 02:13 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
Originally Posted by @nthony
its called a "vin diesel special" in the ricer forums.
LMAO!!...
Old 09-26-2006, 02:42 PM
Arctic2002ss's Avatar
I shift my truck('92 Chevy 1/2 ton) occasionally without using the clutch. It only allows that at low rpms and light throttle though. I have not tried it on the SS and don't really plan to.
Old 09-26-2006, 02:57 PM
Somebody09's Avatar
I heard someone talk about straight-cut gears for a transmission once when talking about power shifting... I didn't do any research because my Google (or whatever search you like) is broken. Anyone know anything about that?
Thanks!
(this is actually interesting to me)
Old 09-26-2006, 06:37 PM
  #32
Administrator
unit213's Avatar
Indeed it is. Perhaps it's that same simple mind that doesn't know what
powershifting is then proceeds to give false information to a guy who
does know what it means.
I can rev my motor to 8,000rpm too. Just like your father can shift
without using the clutch. Both would be stupid. Got it?
Sounds good. Be sure to explain things correctly next time as well ok.
Thanks.
Old 09-26-2006, 07:00 PM
  #33
spy2520's Avatar
i heard the guy that gets those crazy times on stock cars doesnt use the clutch to shift for GMHTP. as a matter of fact, i just might try to dig up that issue to double check, it was from this year because i havent had a subscription that long.
seemed like some kind of voodoo when i first read it, "shifting with no clutch..."
Old 09-26-2006, 07:42 PM
  #34
AronZ28's Avatar
No. . . . That guy powershifts and is one hell of a driver.
Old 09-26-2006, 08:42 PM
  #35
Tech Resident
ChocoTaco369's Avatar
i got a 4L60E. every shift's a powershift in my car
Old 09-26-2006, 08:58 PM
  #36
burnzilla's Avatar
Thanks.
When I say he showed me "once", obviously to the reader, that should mean, "once".
Yes its the not greatest thing for the car, but it was more of a learning lesson for me.
No, nor he or I do that to our cars, I am very picky about the way my cars looks and drives and rarely misuse it.
In any case, your "comment" about brilliant was sarcastic and uncalled for when obviously this was a one time thing.
I dont mind sarcastic comments, and like anyone else, love to learn new things Unit, but somethin about your comment did not sit well. Maybe it was the part where you were being sarcastic about me and my old man.
Old 09-26-2006, 09:11 PM
  #37
2001bluerata's Avatar
Right on the nose.
When you let off the gas to shift the RPMs have to come back up, if you keep your foot down on the gas then the RPMs stay up until very quickly tap the clutch and slam it into the next gear. Not something I would recommend if you can't shift worth a damn, but at least you have your rev limiter!
Old 09-26-2006, 09:27 PM
  #38
Power Shift.
Old 09-27-2006, 08:53 AM
  #39
Administrator
unit213's Avatar
My apologies then.
Old 09-27-2006, 09:56 AM
  #40
KameleonTransAm's Avatar
^ DAMN STRAIGHT
Quick Reply: Double Clutching......
