Double Clutching......
#41
Powershifting should be used at the track but can be used on the street. You have more of a risk of missing a shift and blowing a gear when powershifting.
Shifting without the clutch is nothing more then letting off the gas and putting pressure on the gear to let it fall in. It is called Rev-matching. When the engine RPM and trans RPM are the same then the syncro and gear will automatically line up, hence letting the gear engage without disengaging the clutch. I use it when I'm lazy or when I'm bored and not use the clutch so my passenger can see. It is definately not for race use since you have to wait a second while letting off.
Remember to always make sure you hit that gear!
#42
Originally Posted by Somebody09
I heard someone talk about straight-cut gears for a transmission once when talking about power shifting... I didn't do any research because my Google (or whatever search you like) is broken. Anyone know anything about that?
Thanks!
(this is actually interesting to me)
Thanks!
Real, true racing sequential transmissions should be shifted without a clutch (again after clutching into 1st). But again the noise is unbearable, and the cost is waaay more than an f body when it was new!!
#44
Originally Posted by SantaCruz163
Isn't double clutching to prevent blowing the welds on the intake?
#45
Location: The dirty taint of the country. ...Los Angeles
Double Clutching is something for truck drivers in rigs. I remember after Fast and the Furouse came out,...EVERY frig'n kid couldn't stop using that damn phrase!!
#48
I have to have a 13 second car.
Quite frankly, if you blow a gear or miss a gear while powershifting then you should probably never drive a stick. Well, that was a bit extreme. If you are going to powershift, practice shifting very quickly in a safer enviroment. I hear people have a hard time with third gear. If you practice it and still want to do it, then do it. When I powershift at the track I just spin. So I granny shift and baby it off the line..
Because not being able to powershift at the track has NOTHING to do with my stock 10 bolt and shitty street tires.
#50
Originally Posted by james562
damn you kidz is rookiez just rev it to 6000 and pop it in to to drive. Thats the only way to powershift
You need bring it up to 6000 while on the highway, pop it into reverse, go into a 180 spin and flip off the car in front of you
#51
actually the best move is to do all that and make sure a cop can see you do it. then to get away you can use a whole bunch of cars like yours to drive around till you get away.
#52
Shifting without the clutch is slam boxing. I did it in my Saturn all the time. It worked great. The synchros were pretty free or something. I would never do it in my car. I know how but will not.
It is in Unit's nature as a mod to be sarcastic and rib people for stupid coments and wrong info. I don't blame him. I did not like it at first but after being on here a while I saw why. Too much ignorance on this site and the egos to go along with it. You loose patience after a while for that junk. Now I have great respect for the mods here and have gained much knowledge to pass on to others.
#53
#55
cmon guys it works, I pull c6 zo6's from a dig all day long with this method Just make sure you have your car tuned to have the transflux capaciter engauge at WOT
#57
Originally Posted by KameleonTransAm
Duh....transflux capaciter
Geez you noobs
Geez you noobs
I got .7's on my 1/4 with that and the engine oil bypass kit.
Next week, im thinkin about ordering the O-Pipe.
#59
Originally Posted by Demon_Speeding
The last time I double clutched while I was spraying the fsking passenger floorboard fell out! Of course that was after my laptop was warning about "danger to manifold"...
