traction control question
If you want the ability to turn it off,..SLP sells a TCSModule for the LS1. F.Y.I. Its only a good idea to turn it off if your racing anmd not good if you leave it off for daily driving.
by the way i didnt ignore your original post, my computer somehow managed to avoid displaying it.
thanks again for the replies
It doesn't light up for the same reason there is no switch - you don't have traction control. If it doesn't exist it can't be switched off.
To be honest it's pretty easy to tell driving the car, just pull out of a turning while accelarating hard. If it lights the tyres up and doesn't kick back thru the pedal you have confirmation that TCS is not part of your car.
The SLP modula is designed to set the default mode to OFF as cars equiped with TCS always reset to ON each time you start the engine.
And on dry roads it's perfectly safe to drive with TCS off, providing you can drive.
If you have TCS it will kick in, from a hard launch, pulling out of a turning, kick down 2nd to 1st, WOT up change 1st to 2nd and many other occasions.
It is really evident when it kicks in, as the throttle pedal will kick back at you, you'll hear a chattering sound of the system working, rpms will drop or cease increasing as much, accelaration will reduce and a brigth yellow 'Low Trac' warning will be displayed on the dash. It will not prevent wheel spin, but it will try and limit it.
When i'm warm'n up,..my second gear sucks. My rpms just drop. Thats why i only hold it there for a second before I hit 3rd.
Secondly,.... I've never cared about the TCS. Never had an issue with it at all at the track or while im daily driving. In fact,...I wasn't even the one who originally noticed that their wasn't a switch,.....my friend did.
Thirdly,....If im mistaken or if i've made an incorrect statement,.....then correct me,.but DON'T disrespect me!! I didn't insult you. We're on here to learn from one another and share thoughts,........NOT to get mocked! Don't be ****'n stupid!
