Build dates, RPO's, service records, want them?
Beings I have access to GM Dealerworld, which includes SI and VIS, I can check the following:
Vehicle Build Dates - GM dates not SLP or ASC
Warranty Start Date - When it was sold
Delivering Dealer - Where it was delivered when NEW
Claim History - All history performed by a GM dealer
Recall/Campaigns - Any open recalls or campaigns
Vehicle Build - All options the car is equipped with from GM when new
All I need is the last 8 digits of your GM vehicle. I can get this info for any year between 96 and 07. Some cars VIS only gives the option codes rather than both the option codes with decsriptions. Give me a day or so to get back to you as I imagine I may get a handful of requests.
Here is my cars info just to show what it includes:
Delivering Dealer :
MOORE CADILLAC PONTIAC INC
15950 MANCHESTER RD
ELLISVILLE , MO 63011-2170
Build Date : 10/05/2000
Warranty Start Date : 02/01/2001
OPTION CODES
AAA - STANDARD EQUIPMENT PROCESSING OPTION
AG1 - POWER SEAT, DRIVER 6-WAY
AK5 - DUAL FRONTAL AIR BAGS
AQ9 - CUSTOM BUCKET SEATS W/ADJUSTABLE LUMBAR SUPPORTS
AU0 - REMOTE KEYLESS ENTRY
AU3 - POWER DOOR LOCKS
A31 - POWER WINDOWS
BBS - HURST SHIFTER
CAF - HANDLING CHARGE-ST. THERESE TO AMERICAN SUNROOF
CC1 - LOCKING HATCH ROOF, REMOVABLE
C60 - AIR CONDITIONING, CUSTOM
DE4 - HATCH ROOF SUNSHADES, REMOVABLE
DG7 - DUAL POWER SPORT MIRRORS
DL5 - DECAL ROADSIDE SERVICE
FE4 - RIDE & HANDLING SPECIAL SUSPENSION SYSTEM
FE9 - 50-STATE LOW EMISSION VEHICLE
GU6 - 3.4 RATIO REAR AXLE
G80 - LIMITED SLIP TORSEN REAR DIFFERENTIAL
IL2 - TRIM INTERIOR DESIGN
J65 - BRAKES, PWR 4-WHL,DISC FRT & RR
K43 - 102 AMP GENERATOR
LS1 - 5.7 LITER SFI V8 ENGINE
MM6 - TRANSMISSION, 6-SPEED MANUAL
MN6 - TRANSMISSION, 6-SPEED MANUAL
NF7 - FEDERAL LOW EMISSION
NP5 - STEERING WHEEL, LEATHER WRAPPED W/LEATHER WRAPPED SHIFT ****
NW9 - TRACTION CONTROL, ELECTRONIC
PBT - TEMP. WHL & TIRE-UPFITTER DLVY
QFK - TIRES, P275/40ZR17 SPEED RATED
QF6 - 5-SPOKE 17" HIGH POLISHED ALUMINUM WHEELS
R6J - CDN
R7X - SECURITY PACKAGE CONSISTS OF: THEFT DETERRENT SYSTEM REMOTE KEYLESS ENTRY
R9P - POWER PACKAGE INCLUDES: POWER DOOR LOCKS RETAINED ACCESSORY POWER, POWER WINDOWS INCLUDING EXPRESS DOWN DRIVER'S SIDE DUAL POWER SPORT MIRRORS POWER ANTENNA STE - ASM PLT ST. THERESE
T43 - SPOILER, REAR DECK LID
T78 - HEADLAMP CONTROL DELETE
UA6 - THEFT DETERRENT SYSTEM
UB3 - RALLY GAGES W/TACHOMETER
UK3 - LEATHER WRAPPED STEERING WHEEL W/RADIO CONTROLS
U75 - POWER ANTENNA
VM3 - BUMPER STD IMPACT 5 MPH FRT &RR
V12 - POWER STEERING COOLING SYSTEM
V73 - VEHICLE CERTIFICATION U.S.
WS6 - RAM AIR PERFORM.& HANDLING PKG: * RAM AIR INDUCTION SYSTEM * FUNCTIONAL AIR SCOOPS * 17" HIGH POLISHED ALUMINUM WHEELS * P275/40ZR17 SPEED RATED TIRES * SPECIFIC LOW RESTRICTION DUAL EXHAUST SYSTEM * SPECIFIC TUNED SUSPENSION * POWER STEERING COOLER
WS9 - FORMULA OPTION
W55 - RADIO ETR AM/FM STEREO W/COMPACT DISC PLAYER AND GRAPHIC EQUALIZER, INCL. CLOCK, SEEK UP/DOWN, REMOTE CD PRE-WIRING, MONSOON 500 WATT PEAK POWER W/10 SPEAKER PREMIUM SOUND SYSTEM AND STEERING WHEEL, LEATHER WRAPPED, W/RADIO CONTROLS
Y82 - TRANS AM OPTION
1AY - ORDER MODIFICATION STOCK
1SA - OPTION GROUP - 1SA
19I - INT TRIM, EBONY
192 - TRIM, EBONY
41U - PAINT, BLACK
6ZM - COMPONENT FRT LH COMPUT SEL SUS
7ZM - COMPONENT FRT RH COMPUT SEL SUS
8TJ - COMPONENT RR LH COMPUT SEL SUSP
9TJ - COMPONENT RR RH COMPUT SEL SUSP
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
07/06/2004 010894 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 67572 miles
04/23/2002 329239 # N1760 - FLASHER - TURN SIGNAL - REPLACE 26001 miles
12/22/2000 299008 # V0632 - INSPECT RADIATOR CAP INSTALL NEW CAP IF NECESSARY 5 miles
10/05/2000 A17531 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Delivering Dealer :
15950 MANCHESTER RD
OPTION CODES
A31 - POWER WINDOWS
BBS - HURST SHIFTER
R6J - CDN
U75 - POWER ANTENNA
192 - TRIM, EBONY
41U - PAINT, BLACK
CLAIM HISTORY
LS1Tech Administrator
Received 1,724 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
W2137307
W = 1998.
Thanks.
W = 1998.
Thanks.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Originally Posted by joshp14
PM sent
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
Have a drink on me.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Originally Posted by SuperSport623
Based off the VIN above, the car is a model year 1994....is this correct?
