Safe REV range?
Old Feb 20, 2007 | 09:11 AM
Stringfellow's Avatar
Default Safe REV range?
Its been awhile since I had my last LS1, when they were new and we didn't know about them yet.
Anyway, I have another with an M6. What is the highest I could REV it before worrying about oil starvation, floating valves, bending pushrods?
A friend of mine said he's been through many pushrods in his M6, although, he rods the hell out of his. I know there is the factory REV limiter, but should I exercise more caution then that?
Old Feb 20, 2007 | 09:39 AM
SladeX's Avatar
100rpm before rev limiter is when I usually shift at the track...
I also like to rip it to 6k rpm every once in awhile, weather permitting...
It's the dreaded 5-2 shift or lesser 3-2 shift that will kill pushrods. The valve float usually occurs well past rev limiter. On the 98 cars, the rod bolts don't like rpm's above 6200, so that's an issue when doing heads and cam, may upgrade rod bolts as a precaution.
Old Feb 20, 2007 | 10:24 AM
Blk97WS6's Avatar
what mods are done to the car? and dont forget about the weak rod bolts in the 98-00 models.
Old Feb 20, 2007 | 12:20 PM
Car is completely stock for now except with the skip shift elim.
Its an 01 10th anniversary Hawk
I will prob mod it a little, but not for at least a yr or two.
When so, I'll do an ATI SC and cam with SLP full exhaust and the rest of the nessessary upgrades to support a blower.
Old Feb 20, 2007 | 04:38 PM
KW4life06's Avatar
do gmmg exhaust if u want people to orgasm
Old Feb 20, 2007 | 06:20 PM
99Z28LS1's Avatar
i would say the same, i really wouldnt go that far unless i was at the track. mine is set to 6500, but i have the springs and cam to match that
i used to shift right at 5.5 when i was N/A....... actually i shifted right at 5k when i got turboed because my car wouldnt make any power over 5k because the springs and cam wouldnt take that
Old Feb 20, 2007 | 06:29 PM
Sluggish's Avatar
your shifting to high.....try 5500......you should get a better trap speed and dropped that et.....I had my car dynoed and it made its power at 5450.......with the mods above my et in sig
Old Feb 20, 2007 | 06:40 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
"safe" rpm limit with stock valvesprings is 6200rpm. Can you raise the rev limiter and shift higher than 6200 without immediate failure? Sure, but higher than 6200 isn't really safe with the stock springs. That's the point in the rev limiter.
Old Feb 20, 2007 | 06:46 PM
RPM WS6's Avatar
Odd. My '98 has never seen the track, but I noticed the oppsite condition with my '00 car when it had just a lid and catback. I always ETed and Trapped better when shifting at 5900-6000rpm. Shifting any lower had poor results. I realize that the stock cam peaks well before 6000rpm, but the problem with shifting at 5500 is how low the rpms drop after the upshift. When you shift at 6k, the shift extension will put you at a more favorable rpm than if you shift at 5500. Also, you will be making more power at 5600, 5700, 5800, than what you'll be making in the next gear after the rpms drop off with an upshift at 5500 assuming you have a stock stall speed TC (auto cars). Maybe the M6 cars are a little different due to gearing.
But if it works for you then I guess you might as well stick with it. That didn't work for me though.
Old Feb 20, 2007 | 06:56 PM
SladeX's Avatar
While you tell me I shift to high up, track results would say otherwise.
I have my dyno and track runs to determine my shift points.
I make my peak power at 52-5300rpm, but it floats at that hp level until rev limiter. The torque curve also indicates that my curve is relatively flat up to that point, while I may peak at 4krpm with torque, I still have over 300 ft/lb up to 6200rpm.
I tried doing a peak hp rpm shift but found myself consistently slower. I find I am really hurting on my 60 ft at the moment so this winter's mod's included LCA's and a better clutch. To hit 106mph 13.8 with a 2.6 60 ft shows me where I'm really hurting right now.
Old Feb 20, 2007 | 08:14 PM
5_02ls1's Avatar
i set mine to shift at 6k and the rev limiter at 6.3k never had any valve floatwith my mods in sig the car pulls strong all the way to 6k
Old Feb 21, 2007 | 02:16 AM
freni32's Avatar
dont know about your car but mine loses power right at 5800-6000 rpm... no need to carry it past that... just losing power
Old Feb 21, 2007 | 11:44 AM
99Z28LS1's Avatar
you think its hard shifting at a certain point, wait til you get a turbo and you mash it, wait for the little lag and bam.... it PULLS you til you let off, before i had my cam and springs, i would bounce off the limiter because i wasnt ready for the car to pull me to higher RPM like that, but after i got the cam and springs, i didnt really have to worry that much because i can support it. it still feels weird to shift at 6500, i normally shift between 61-6200 because it doesnt really make that big of a difference in my opinion. but i race more on the street as apposed to the track
Old Feb 21, 2007 | 12:32 PM
MeentSS02's Avatar
Kleeborp the Moderator™
You are missing one important point...it isn't where you are at in the power band when you shift out of a gear...it is where you land in the power band in the next gear. While you may peak out at 5500-ish, it is usually to your benefit to shift higher than that point since you will fall back into a more advantagous spot in your power band (like 4400 RPMs instead of something like 4000 RPMs).
Grab your dyno graph, and put the information in this link (you'll have to pick the points):
http://www.bgsoflex.com/shifter.html
Old Feb 21, 2007 | 12:48 PM
MeentSS02's Avatar
Oh, and as for a save Rev range, I've taken mine to 6300 RPMs on many occassions, and it is still holding in there. Stock cam, stock valve springs, just bolt-ons.
Old Feb 21, 2007 | 01:29 PM
98Z28MASS's Avatar
Id say keep it at the factory rev limiter, which is 6200 rpms I believe. As someone else stated its the missed shift that usually bends pushrods. For exhaust I wouldnt go full slp, I would do kooks headers, ory, and cutout mated to your stock exhaust. It will sound mean.
