I just hit 72,000 miles
just do your regular maintenance. I'm at 82,5XX and I change my synthetic every 4k for having a boosted motor. flush the trnny if you haven't done it in a while, check all the fluids. do a walk around and check everything fellas
How do I drain the radiator fluid? How do I drain the old coolant and refill it?? Also what fuel filter should I get? I'm going to get me some new spark plug wires and I was wondering what ones you would recommend and what length?? Sorry for all the questions..
When you change the radiator fluid just make sure that you don't leave any air in the system. If you want to watch a bunch of guys argue then look up the DexCool vs regular antifreeze thread here. If you haven't changed the fuel filter it is probably at least partly plugged. It's behind the drivers rear tire, easy to change, you'll get drenched in gas. I do mine every year. I put Taylor plug wires on mine and like them, they eliminate the damn heat tubes and springs in the stock ones, but there are other aftermarket ones that are good to. I change my Mobile 1 synthetic oil every time the seasons change. That's overkill but I plan on keeping the car. Good luck, oh, if you haven't washed it yet, the paint is cured enough by now.
